    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.3k Views 66 Watching
    • tt_suT
      tt_su
      Maybe these files where created before you had full access to the plugins folder?
      In any case, the files in VirtualStore should either be moved to the actual Plugins folder or removed.
      • micioneM
        micione
        Charly same problem. (In SU8).
        I have full access to the plugins folder.
        And the folder "virtual store" is empty.
        • charly2008C
          charly2008
          Hi Thomas,
          Previously I always had full access as an administrator. The Content from the virtual store, I moved to the plugins folder. The message still appears.
          I have tried again with TT_Lib2-2.9.2.rbz but the result is the same.
          I have now switched back to TT_Lib2-2.8.3.rbz. No Problems.
            Being an administrator does not guarantee full security permissions to folders within the Program Files tree. By default everyone gets 'read-only'.
            So you need to select the Plugins folder's icon:
            right-click
            context-menu
            Properties
            Security
            Edit...
            and give every entry FULL permissions
            Apply/OK.
            Also in the same folder as the Plugins folder find SketchUp.exe, select it and:
            right-click
            context-menu
            Properties
            Compatibility
            Tick the 'Always run as administrator' box...
            Apply/OK.
            Also make sure that the Plugins folder does not have a custom icon - this is known to have subtle effects on permissions that report FULL but are really slightly reduced 😒
            • tt_suT
              tt_su
              After you removed the content of the VirtualStore Plugins folder - did you also remove it?
              (I might have to change the detection code to not raise a message if the folder exist but is empty. At the moment it will alter the user by just being there.)
              • micioneM
                micione
                Thomas,
                The procedure indicated by TIM has been active for a long time on my computer.
                The folder "virtual store" is empty.
                But the warning reappears always, to the opening of SU8.
                Earlier Library, as well as all installed plugins, do not have
                given problems.
                In SU2013, the question does not arise. The thing does not happen.
                • G
                  g_wilson
                  @tt_su said:
                  Thanks for the feedback. I think I have a fix - but I don't have an XP machine to test on.
                  I've uploaded a new version on BitBucket: https://bitbucket.org/thomthom/tt-library-2/downloads
                  Can you try that and let me know if it works. Then I can upload it to the Plugin Store and Extension Warehouse.
                  Hi - 2.9.2 same Load Errors as 2.9.1 Tried change rbz => zip => unpacked => copied to "plugins" and also installed directly thru Preferences as rbz. Same results. Also deleting TT_lib folder and .rb before installing 2.9.2.
                  I guess the time is coming to change OS to something that doesn't require the use of hi grade metallurgical anthracite.
                  Error Loading File tt_cleanup.rb
                  can't convert nil into StringError Loading File tt_shell.rb
                  can't convert nil into StringError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/tt_solid_inspector/core.rb
                  can't convert nil into StringError Loading File tt_solid_inspector.rb
                  From Ruby Console:
                  ENV.each { |k,v| puts "#{k} = #{v}" }
                  ALLUSERSPROFILE = C:\Documents and Settings\All Users
                  APPDATA = C:\Documents and Settings\Gary\Application Data
                  CLIENTNAME = Console
                  CommonProgramFiles = C:\Program Files\Common Files
                  COMPUTERNAME = GARY-48BB76102C
                  ComSpec = C:\WINDOWS\system32\cmd.exe
                  FP_NO_HOST_CHECK = NO
                  HOMEDRIVE = 😄
                  HOMEPATH = \Documents and Settings\Gary
                  LOGONSERVER = \GARY-48BB76102C
                  NUMBER_OF_PROCESSORS = 2
                  OS = Windows_NT
                  Path = C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared;C:\WINDOWS\system32\WindowsPowerShell\v1.0
                  PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
                  PROCESSOR_ARCHITECTURE = x86
                  PROCESSOR_IDENTIFIER = x86 Family 15 Model 67 Stepping 3, AuthenticAMD
                  PROCESSOR_LEVEL = 15
                  PROCESSOR_REVISION = 4303
                  SESSIONNAME = Console
                  SystemDrive = 😄
                  SystemRoot = C:\WINDOWS
                  TEMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
                  TMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
                  USERDOMAIN = GARY-48BB76102C
                  USERNAME = Gary
                  USERPROFILE = C:\Documents and Settings\Gary
                  windir = C:\WINDOWS
                  {"ALLUSERSPROFILE"=>"C:\Documents and Settings\All Users", "APPDATA"=>"C:\Documents and Settings\Gary\Application Data", "CLIENTNAME"=>"Console", "CommonProgramFiles"=>"C:\Program Files\Common Files", "COMPUTERNAME"=>"GARY-48BB76102C", "ComSpec"=>"C:\WINDOWS\system32\cmd.exe", "FP_NO_HOST_CHECK"=>"NO", "HOMEDRIVE"=>"C:", "HOMEPATH"=>"\Documents and Settings\Gary", "LOGONSERVER"=>"\\GARY-48BB76102C", "NUMBER_OF_PROCESSORS"=>"2", "OS"=>"Windows_NT", "Path"=>"C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared\;C:\WINDOWS\system32\WindowsPowerShell\v1.0", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1", "PROCESSOR_ARCHITECTURE"=>"x86", "PROCESSOR_IDENTIFIER"=>"x86 Family 15 Model 67 Stepping 3, AuthenticAMD", "PROCESSOR_LEVEL"=>"15", "PROCESSOR_REVISION"=>"4303", "ProgramFiles"=>"C:\Program Files", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\WINDOWS", "TEMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "TMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "USERDOMAIN"=>"GARY-48BB76102C", "USERNAME"=>"Gary", "USERPROFILE"=>"C:\Documents and Settings\Gary", "windir"=>"C:\WINDOWS"}
                    @micione said:
                    Thomas,
                    That's because the previous versions would simply check if there was a Plugins folder in the VirtualStore. It didn't check if it was empty.
                    I just uploaded a new version that checks if there actually is files there before warning. I think that should fix this.
                      Wait - these are different errors... don't think that is related to the VirtualStore.
                      All these errors refer to other plugins.
                      What's the output if you open the Ruby Console and type in: load 'tt_cleanup.rb' ?
                      • micioneM
                        micione
                        Thomas,
                        The new version 2.9.3 seems to have solved the problem.
                        Thank you.
                        • G
                          g_wilson
                          Hi again - this may be a wild goose chase. I just closed SU8 and after exiting - up pops bugsplat window. I have attached .dmp file - closed bugsplat without being smart enough to send to trimble but searched out .dmp file. I tried 4 times to repeat bugsplat but no joy - exited cleanly. The bugsplat occurred with a new blank my default .skp as per usual.
                          OOPS - won't send .dmp file - renamed .txt
                          Stubborn bloody thing - now attached as .zip
                          SketchUpLUA15091.zip
                          • G
                            g_wilson
                            Per request RESULT:
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
                            Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in virtualstore_check'
                            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:450
                            C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89:in require' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89 (eval):232:in load'
                            (eval):232
                            • tt_suT
                              tt_su
                              @micione said:
                              Thomas,
                              Thank you.
                              So this crash doesn't repeat itself?
                              Have you also tried the latest 2.9.3 version? Are things working better then?
                              • tt_suT
                                tt_su
                                hm.... this might be yet another bug. Let me just quickly update with a new patch.
                                (I wish I had access to an XP machine right now...) 😞
                                  Ok - version 2.9.4 up for grabs!
                                  (And at the PluginStore - I think - if I managed to update that correctly...)
                                  Update bonanza... 😒
                                  • G
                                    g_wilson
                                    Yes - I tried 2.9.3 - same result.
                                    Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in virtualstore_check'
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:454
                                    (eval):232
                                    • G
                                      g_wilson
                                      SUCCESS !!! Thank you Thomas. Have nominated you for the "TIG" award for fast service.
                                      • tt_suT
                                        tt_su
                                        Whohoo! Sorry for the inconvenience - had I had a copy of XP it would have been fixed earlier.
                                        • irwanwrI
                                          irwanwr
                                          Thank you very much, Thomas.
                                          Love you 😄
                                          I don't know how to do this though;
                                          @tt_su said:
                                          Hmm... must be some differences in the environment variable between Win8/7/Vista and XP.
                                          Can you open the Ruby Console and give me the result of ENV.each { |k,v| puts "#{k} = #{v}" } ? Then I can make a patch for this.
                                          Thanks to Gary Wilson for the help 😄
                                          • tt_suT
                                            tt_su
                                            irwanwr: did 2.9.4 fix the error message you where getting?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
