    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.3k Views 66 Watching
    • tt_suT
      tt_su
      @micione said:
      Thomas,
      The new version 2.9.3 seems to have solved the problem.
      Thank you.
      @g_wilson said:
      Hi again - this may be a wild goose chase. I just closed SU8 and after exiting - up pops bugsplat window. I have attached .dmp file - closed bugsplat without being smart enough to send to trimble but searched out .dmp file. I tried 4 times to repeat bugsplat but no joy - exited cleanly. The bugsplat occurred with a new blank my default .skp as per usual.
      OOPS - won't send .dmp file - renamed .txt
      Stubborn bloody thing - now attached as .zip
      So this crash doesn't repeat itself?
      Have you also tried the latest 2.9.3 version? Are things working better then?
      • tt_suT
        tt_su
        @g_wilson said:
        Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in virtualstore_check'
        hm.... this might be yet another bug. Let me just quickly update with a new patch.
        (I wish I had access to an XP machine right now...) 😞
          Ok - version 2.9.4 up for grabs!
          https://bitbucket.org/thomthom/tt-library-2/downloads
          (And at the PluginStore - I think - if I managed to update that correctly...)
          Update bonanza... 😒
          • G
            g_wilson
            Yes - I tried 2.9.3 - same result.
            Error Loading File tt_cleanup.rb
            can't convert nil into StringError Loading File tt_shell.rb
            can't convert nil into StringError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/tt_solid_inspector/core.rb
            can't convert nil into StringError Loading File tt_solid_inspector.rb
            load 'tt_cleanup.rb'
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
            Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in virtualstore_check'
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:454
            C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89:in require' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89 (eval):232:in load'
            (eval):232
            • G
              g_wilson
              SUCCESS !!! Thank you Thomas. Have nominated you for the "TIG" award for fast service.
              • tt_suT
                tt_su
                Whohoo! Sorry for the inconvenience - had I had a copy of XP it would have been fixed earlier.
                • irwanwrI
                  irwanwr
                  Thank you very much, Thomas.
                  Love you 😄
                  I don't know how to do this though;
                  @tt_su said:
                  Hmm... must be some differences in the environment variable between Win8/7/Vista and XP.
                  Can you open the Ruby Console and give me the result of ENV.each { |k,v| puts "#{k} = #{v}" } ? Then I can make a patch for this.
                  Thanks to Gary Wilson for the help 😄
                  • tt_suT
                    tt_su
                    irwanwr: did 2.9.4 fix the error message you where getting?
                    • guanjinG
                      guanjin
                      2.9.4+Selection_Toys,In Sketchup8 windows XP, open the dialog, automatic sketchup8 quit after tens of seconds, without any prompting。
                      Edge Tools,Can not be used, loading errors。
                      • tt_suT
                        tt_su
                        That is strange. I cannot reproduce that. By the way, Selection Toys has never used TT_Lib2. I used TT_Lib1 for a while - but I made it stand-alone earlier this year. What version of Selection Toys do you have? And if you have only Selection Toys loading, does it still crash?
                        What are these loading errors? (I can't do much without them.) Also, what version of Edge Tools.
                        • guanjinG
                          guanjin
                          Selection Toys loading2.36 Edition。
                          UV Toolkit v2.31
                          Are not available。Earlier versions without problems。
                          • guanjinG
                            guanjin
                            [attachment=0:32tfbp3s]<!-- ia0 -->QQ图片20131211190130.jpg<!-- ia0 -->[/attachment:32tfbp3s]
                            UV Toolkit v2.31
                            TT_Lib2 2.8No problem, you can normally use
                            • guanjinG
                              guanjin
                              tt_selection_Tools ,In 2013 the working properly
                              • tt_suT
                                tt_su
                                I'm sorry, but I am a bit confused now. Which plugins work and which plugins doesn't work?
                                Also, if there are error messages - what do they say?
                                • guanjinG
                                  guanjin
                                  1.tt_selection_Tools ,In sketchup8 Does not work,After opening the tool, sketchup automatically exit after a few seconds。
                                  • tt_suT
                                    tt_su
                                    Hm. I'm unable to reproduce this. Maybe it happens only on XP. I have to ask someone to test for me.
                                    Does it happen if you have only Selection Toys installed?
                                    • guanjinG
                                      guanjin
                                      Did not happen, but the old version 2.2 can be used normally
                                      • tt_suT
                                        tt_su
                                        hm.. if you can load Selection Toys alone, but not with the rest of your plugins it sounds like a clash. Any chance you can find out which plugin it clashes with?
                                        • guanjinG
                                          guanjin
                                          Version 2.2 normal way? It will not conflict.
                                          2.36 will flash back it?
                                          • tt_suT
                                            tt_su
                                            I'm sorry, but what do you mean by "flash back"?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
