    [Plugin] TT_Lib²
    310 Posts 66 Posters 479.5k Views 66 Watching
    • G
      g_wilson
      Hi Thomas - I'm am having same problem with 2.9.1 - reverted to 2.8.3 and all is well. Here is my similar Ruby info you requested of irwanwr:
      ENV.each { |k,v| puts "#{k} = #{v}" }
      ALLUSERSPROFILE = C:\Documents and Settings\All Users
      APPDATA = C:\Documents and Settings\Gary\Application Data
      CLIENTNAME = Console
      CommonProgramFiles = C:\Program Files\Common Files
      COMPUTERNAME = GARY-48BB76102C
      ComSpec = C:\WINDOWS\system32\cmd.exe
      FP_NO_HOST_CHECK = NO
      HOMEDRIVE = 😄
      HOMEPATH = \Documents and Settings\Gary
      LOGONSERVER = \GARY-48BB76102C
      NUMBER_OF_PROCESSORS = 2
      OS = Windows_NT
      Path = C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared;C:\WINDOWS\system32\WindowsPowerShell\v1.0
      PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
      PROCESSOR_ARCHITECTURE = x86
      PROCESSOR_IDENTIFIER = x86 Family 15 Model 67 Stepping 3, AuthenticAMD
      PROCESSOR_LEVEL = 15
      PROCESSOR_REVISION = 4303
      SESSIONNAME = Console
      SystemDrive = 😄
      SystemRoot = C:\WINDOWS
      TEMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
      TMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
      USERDOMAIN = GARY-48BB76102C
      USERNAME = Gary
      USERPROFILE = C:\Documents and Settings\Gary
      windir = C:\WINDOWS
      {"ALLUSERSPROFILE"=>"C:\Documents and Settings\All Users", "APPDATA"=>"C:\Documents and Settings\Gary\Application Data", "CLIENTNAME"=>"Console", "CommonProgramFiles"=>"C:\Program Files\Common Files", "COMPUTERNAME"=>"GARY-48BB76102C", "ComSpec"=>"C:\WINDOWS\system32\cmd.exe", "FP_NO_HOST_CHECK"=>"NO", "HOMEDRIVE"=>"C:", "HOMEPATH"=>"\Documents and Settings\Gary", "LOGONSERVER"=>"\\GARY-48BB76102C", "NUMBER_OF_PROCESSORS"=>"2", "OS"=>"Windows_NT", "Path"=>"C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared\;C:\WINDOWS\system32\WindowsPowerShell\v1.0", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1", "PROCESSOR_ARCHITECTURE"=>"x86", "PROCESSOR_IDENTIFIER"=>"x86 Family 15 Model 67 Stepping 3, AuthenticAMD", "PROCESSOR_LEVEL"=>"15", "PROCESSOR_REVISION"=>"4303", "ProgramFiles"=>"C:\Program Files", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\WINDOWS", "TEMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "TMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "USERDOMAIN"=>"GARY-48BB76102C", "USERNAME"=>"Gary", "USERPROFILE"=>"C:\Documents and Settings\Gary", "windir"=>"C:\WINDOWS"}
      • tt_suT
        tt_su
        Thanks for the feedback. I think I have a fix - but I don't have an XP machine to test on.
        I've uploaded a new version on BitBucket: https://bitbucket.org/thomthom/tt-library-2/downloads
        Can you try that and let me know if it works. Then I can upload it to the Plugin Store and Extension Warehouse.
        • charly2008C
          charly2008
          I have installed "TT_Lib_v2.9.1.rbz" and now get the message as shown below. I have full access to the plugins folder.
          In the "virtual store" I can only find DEFPARAM_Dir and Fredo6Trace.txt and these exists in the plugins folder.
          Thanks in advance for a hint.
          Charly
          • tt_suT
            tt_su
            Maybe these files where created before you had full access to the plugins folder?
            In any case, the files in VirtualStore should either be moved to the actual Plugins folder or removed.
            • micioneM
              micione
              Charly same problem. (In SU8).
              And the folder "virtual store" is empty.
              • charly2008C
                charly2008
                Hi Thomas,
                Previously I always had full access as an administrator. The Content from the virtual store, I moved to the plugins folder. The message still appears.
                I have tried again with TT_Lib2-2.9.2.rbz but the result is the same.
                I have now switched back to TT_Lib2-2.8.3.rbz. No Problems.
                  Being an administrator does not guarantee full security permissions to folders within the Program Files tree. By default everyone gets 'read-only'.
                  So you need to select the Plugins folder's icon:
                  right-click
                  context-menu
                  Properties
                  Security
                  Edit...
                  and give every entry FULL permissions
                  Apply/OK.
                  Also in the same folder as the Plugins folder find SketchUp.exe, select it and:
                  right-click
                  context-menu
                  Properties
                  Compatibility
                  Tick the 'Always run as administrator' box...
                  Apply/OK.
                  Also make sure that the Plugins folder does not have a custom icon - this is known to have subtle effects on permissions that report FULL but are really slightly reduced 😒
                  • tt_suT
                    tt_su
                    After you removed the content of the VirtualStore Plugins folder - did you also remove it?
                    (I might have to change the detection code to not raise a message if the folder exist but is empty. At the moment it will alter the user by just being there.)
                    • micioneM
                      micione
                      Thomas,
                      The procedure indicated by TIM has been active for a long time on my computer.
                      The folder "virtual store" is empty.
                      But the warning reappears always, to the opening of SU8.
                      Earlier Library, as well as all installed plugins, do not have
                      given problems.
                      In SU2013, the question does not arise. The thing does not happen.
                      • G
                        g_wilson
                        Hi - 2.9.2 same Load Errors as 2.9.1 Tried change rbz => zip => unpacked => copied to "plugins" and also installed directly thru Preferences as rbz. Same results. Also deleting TT_lib folder and .rb before installing 2.9.2.
                        I guess the time is coming to change OS to something that doesn't require the use of hi grade metallurgical anthracite.
                        Error Loading File tt_cleanup.rb
                        can't convert nil into StringError Loading File tt_shell.rb
                        can't convert nil into StringError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/tt_solid_inspector/core.rb
                        can't convert nil into StringError Loading File tt_solid_inspector.rb
                        From Ruby Console:
                        HOMEDRIVE = 😄
                        OS = Windows_NT
                        SystemDrive = 😄
                        USERNAME = Gary
                        windir = C:\WINDOWS
                          @micione said:
                          Thomas,
                          That's because the previous versions would simply check if there was a Plugins folder in the VirtualStore. It didn't check if it was empty.
                          I just uploaded a new version that checks if there actually is files there before warning. I think that should fix this.
                            Wait - these are different errors... don't think that is related to the VirtualStore.
                            All these errors refer to other plugins.
                            What's the output if you open the Ruby Console and type in: load 'tt_cleanup.rb' ?
                            • micioneM
                              micione
                              Thomas,
                              The new version 2.9.3 seems to have solved the problem.
                              Thank you.
                              • G
                                g_wilson
                                Hi again - this may be a wild goose chase. I just closed SU8 and after exiting - up pops bugsplat window. I have attached .dmp file - closed bugsplat without being smart enough to send to trimble but searched out .dmp file. I tried 4 times to repeat bugsplat but no joy - exited cleanly. The bugsplat occurred with a new blank my default .skp as per usual.
                                OOPS - won't send .dmp file - renamed .txt
                                Stubborn bloody thing - now attached as .zip
                                SketchUpLUA15091.zip
                                • G
                                  g_wilson
                                  Per request RESULT:
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
                                  Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in virtualstore_check'
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:450
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89:in require' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89 (eval):232:in load'
                                  (eval):232
                                  • tt_suT
                                    tt_su
                                    @micione said:
                                    Thomas,
                                    Thank you.
                                    So this crash doesn't repeat itself?
                                    Have you also tried the latest 2.9.3 version? Are things working better then?
                                    • tt_suT
                                      tt_su
                                      hm.... this might be yet another bug. Let me just quickly update with a new patch.
                                      (I wish I had access to an XP machine right now...) 😞
                                        Ok - version 2.9.4 up for grabs!
                                        (And at the PluginStore - I think - if I managed to update that correctly...)
                                        Update bonanza... 😒
                                        • G
                                          g_wilson
                                          Yes - I tried 2.9.3 - same result.
                                          Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in virtualstore_check'
                                          C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:454
                                          (eval):232
                                          • G
                                            g_wilson
                                            SUCCESS !!! Thank you Thomas. Have nominated you for the "TIG" award for fast service.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
