    Gray Lines
    16 Posts 5 Posters 2.8k Views 5 Watching
      jhearcht
      SketchUp 6,4.265, on Windows XP
      I want to show some light lines on my model to represent joints in limestone panels. I don't want them to be actual Edges, just gray shadow lines. I tried drawing on the surface of a group. The lines are tiny when zoomed in, but they look fat when zoomed out or when printed. I tried changing the Edge color, but it didn't seem to make any difference.
      Does anyone know how to draw gray lines in SU?
      • bazB Offline
        baz
        the best way is to use an existing paving material. If however you need a unique pattern you have a bit of work.
        you will need to hand draw your pattern (in pencil?), scan it, import it and convert to material.
        I'm sure someone here will have another way, possibly using layout where line weights are controllable.
        show us how you go.
        baz
          jhearcht
          Thanks for the tip. I finally found the solution I was looking for. At the bottom of the Edit Edge dialog is a box for color. But it was hidden until I stretched the box size. Now I can choose By Material, then select the lines and use the paint bucket to color them. I had previously changed the material, but until I found the edge color box, the material was not displayed.
          • bazB Offline
            baz
            ah, there ya go. you still cant control the 'line weights' tho?
            baz
              jhearcht
              Now I have a new problem. Apparently I have only two choices : all lines black, or all lines By Material. I need to have multiple choices. I want black lines, except in certain cases. White edges on white material just doesn't work. I'll keep looking for a solution.
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                Paint all edges black if they are not already black. Use this procedure:
                1 - Select "Lines color by material".
                2 - Select the "Wire Frame" mode. Only the edges will show.
                3 - Select all.
                4 - Paint them all black.
                After that, get back to the rendering mode of your choice and paint the lines that you want in another color than black, using the color of your choice.
                Just ideas.
                  jhearcht
                  Thanks JL, that's a good idea. I'll try it.
                    jhearcht
                    Unfortunately, after I select all wireframe lines and color black (by material), some of the original faces and textures are rendered as black.
                    So I'm back to square one. Either the lines are all black, or all by material. Apparently I can't have some of each.
                    • wind-borneW Offline
                      wind-borne
                      With ChrisP_ColorEdge plugin you can color your edges in a variety of ways.
                      http://forums.sketchucation.com/viewtopic.php?p=251619#p251619
                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                      %(#BF80BF)[SU 8 pro
                        jhearcht
                        Thanks WB
                        I downloaded the script and unzipped it in the Plug-ins folder. It didn't show-up in the Plug-ins or Tools menu. So I moved a copy of sketchup.rb into the folder. Still SU doesn't automatically import it into the Plug-ins menu. Am I doing something wrong?
                        SketchUp 6.4.265 on Windows XP
                          wind-borne
                          Do you see the toolbar anywhere?
                          Might be the only access.
                          Doesn't show as plugin or tool in menus on my computer.
                          %(#BF80BF)[SU 8 pro
                            Jhearcht ๐Ÿ˜ฎ
                            ๐Ÿ˜• DON'T EVER move files like ' sketchup.rb' !
                            You might break other things!
                            Keep it in ../Tools/, with the other 'system' scripts.
                            The tool you want is accessible from a Toolbar...
                            Menu > View > Toolbars > ColorEdge
                            Read its instructions ๐Ÿ˜’
                              jhearcht
                              I finally found ColorEdge in the Views/Toolbar menu. When selected, a new toolbar appears. So far so good. But after trying every combination I can think of, I still can't get the look I want.
                              When I click a free edge the color changes to the current material selection, in this case a gray color. But that single edit automatically changes all edges in the drawing, including Profiles, to By Material.
                              I want Profiles in black and only selected lines in gray. But apparently there is no way to distinguish between Edges and Profiles in color. It's all or nothing. In my CAD application any object can be given it's own edge and face color. Why is that so hard in SU?
                              I have looked for a plug-in that will allow me to select objects by type and edit them separately from all other objects. But the universal edge color seems to override any custom edits. I tried Color By Layer, but that colors everything on each layer the same. Again, no way to edit each layer separately.
                              Does anyone have any more suggestions????
                                wind-borne
                                Watch the videos?
                                In the earlier image I posted there were 5 shades of gray within the black rectangle
                                Here's a simple block with some colored edges.
                                %(#BF80BF)[SU 8 pro
                                  jhearcht
                                  @wind-borne said:
                                  Watch the videos?
                                  What videos are you referring to?
                                  For a simple box, I could use this plug-in to apply multiple colors . . . as long as the Edge setting is on By Material. But I want the By Material setting to apply only to the colored lines, and leave the Profiles as All Same (black). In other words, I want to have my cake and eat it too. Is that too much to ask?
                                  If I could somehow select all Profile lines, and change their material to Black instead of matching the associated material, that would get closer to what I want. But apparently that's not possible either. None of the Selection Plug-ins seem to work that way.
                                  Oh well, back to the salt mines. ๐Ÿ˜
                                    jhearcht
                                    Since I can't have Gray Edges unless all edges are By Material, maybe there's a way to force the white edges of white materials to receive shadows. Bright white profile lines on a shadowed surface just don't look right. Shadow Settings has an option for From Edges, but not for On Edges.
                                    Does anyone know how to set white material edges to receive shadows?
                                    http://home.mindspring.com/~gnomon/White profiles in shadow.jpg
