    Emissive materials
    renderpluginsextensions
    13 Posts 4 Posters 5.7k Views 4 Watching
    • G Offline
      greenlandboy
      Hi everyone!
      I wanted to ask for a proper step by step guide into how we can create an emissive object?!
      I have been trying all day long to apply the simple emissive material I have created to the surface of some various lamps to light them up!
      But unfortunately unsuccessful, as each time the material rendered is almost black, and the more I increase the intensity of it the darker it goes along with it’s surrounding. I am so confused and tired now that I have given up!! 😞
      Help please...
        @escapeartist said:
        What rendering system are you using?
        He posted in the V-Ray section - but knowing the version would be useful.
        Also, can you post a sample model?
        • G Offline
          greenlandboy
          I am not so sure about what version it is!!I have included an image of it.
          thanks
          render
            Not the most recent one. Question is - is it the very first one?
            If the About section in the Options window - do you see a version number?
            If not - then you have the first one - and with that one you have to use a multiplier of maybe 20000-50000 when you use the Physical Camera.
            • G Offline
              greenlandboy
              thank you a lot πŸ˜„
              it works now πŸ˜› I am so happy, I can finally render my rooms and sub the presentation to my tutor...
              thanks a lot guys!!
              • G Offline
                greenlandboy
                Does anybody know why the light of an emissive material appears grainy in space while the light from the vray rectangular light does not?!
                As the photos show, I have created a cube using vray rectangular light with a multiplier of 100, while the sphere is a sketchup drawn sphere, the material of which is an emissive material of an intensity of 50000. The light is grainier when the emissive material is used. Is that how it always is, or can I improve the light quality that is being displayed by the emissive material?!
                Thanks!
                • G Offline
                  greenlandboy
                  this are the pics
                    Thanks!
                    Remissive material is not intended for main light source - merely for the effect.
                    V-Ray doesn't process emmissive materials in the same manner as lights.
                    • G Offline
                      greenlandboy
                      V-Ray doesn't process emmissive materials in the same manner as lights.[/quote]
                      Ok!!
                      So, if I need to create a lamp to put on to a hanging or other lights, should I make a small cube using the vray rectangular light sides?!
                      Thanks!
                        Lots of rect lights will slow down the render.
                        Can you get away with an omni light?
                        • EscapeArtistE Offline
                          EscapeArtist
                          EDIT: Ahhh, thanks for pointing it out, Thomthom. My mistake. I just click "view new posts" when I login, half the time don't even know what forums there are unless I post a question.
                            arki_xander
                            for Thomthom what if you designed an alcove type of ceiling in a room? So you would recommend it to used rectangular lights than emissive lights because as greenlandboy said that emmisive appears to be grainy ? TIA
                              Yes, I always use "real" lights for main light source. Emmissive material only for the effect.
