    [HELP] which is the best follow-me tool?
    15 Posts 8 Posters 1.8k Views 8 Watching
    • olisheaO
      olishea
      I am looking for a plugin that works like tube along path......except for custom profiles, not just a tube. I seem to remember one posted by a chinese author.....does that ring a bell?
      cheers
      oli
        Line to tubes by Didier Bur
        from Toblerone(3) to Cylinders (12 + ) but intersections are not very completly treated! ๐Ÿ˜ฎ
        Valuable for view objects from distance ๐Ÿ˜„
        Convert arcs, lines, circles, curves to cylinders ( or Toblerone ๐Ÿ˜‰
          Followme and keep by Wikii
          • david_hD
            david_h
            What about Profile Builder? Pretty cool!
              2 faces + path by Kirill2008
              • TIGT
                And some of the Extrusion Tools = e.g. Extrude Face by Rails
                AND of course "FollowMe and Keep" too............
                • olisheaO
                  olishea
                  OK, thanks for the response! ๐Ÿ˜
                  Follow me and keep seems to be working well for my needs, although it can be inconsistent.
                  I forgot about curviloft.....this produced most consistent results.....although you need to manually finish up the connection (I forgot to mention my path is in a continuous loop)
                  The videos for "2 faces + path" don't work anymore....its not consistent though, unexpected results.
                  TIG: You say "extrude face by rails" but I can not see this in the tool set. here is a screengrab of my extrude tools:
                  sorry if I'm being stupid. your extrude tools are sweet btw, I'm just still getting my head round using them. Will make my university work so much easier! My favourite is extrude edges by rails....also extrude edges by vector....very clever (the amount of times I've wanted to push/pull a line!!!!). tell me though, why aren't these plugins for sale?? worth buying.....
                  oli
                    Some examples of what profil you want propagate on what path?
                    • EdsonE
                      Edson
                      do not forget 1001bit tools. in it you will find a tool that works fine every time: extrude along sloping curved path. this most useful set of tools has free and pro versions.
                      edson mahfuz, architect| porto alegre โ€ข brasil
                      http://www.mahfuz.arq.br
                      • N
                        notareal
                        Wonder what happened to Kirill2008? Tutorial videos where taken down...
                        • GaieusG
                          Yes, me too. Hope he's well!
                          • TIGT
                            I meant try these...
                            Extrude Edges by Face [multiple FollowMe]
                            Extrude Edges by Faces [melds two faces along rails like FollowMe with 'morphing']
                            Extrude Edges by Rails by Face [multiple "Extrude Edges by Face" over a 'mesh' surface]
                            each of which does some 'FollowMe-like' stuff............
                            I think I am getting forgetful...
                            I think I am getting forgetful... ๐Ÿ˜‰
                            • utilerU
                              utiler
                              This was a good visual example of the different outcomes, olishea.
                              followmes.skp
                              Just Curious...
                              • olisheaO
                                olishea
                                thanks guys lots of great ways of doing this. TIG i think its just the names of your plugins that confuse me! not saying you should change them or anythin. i think you need a youtube series all to yourself!!
                                cheers for all the help, great forum work guys!! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                oli
                                • TIGT
                                  Know what you mean ๐Ÿ˜’
                                  They confuse me too - and I made them ๐Ÿ˜•
                                  The Extrusion Tools just grew like Topsy and 'EEbyXXX' originally seemed a 'sensible' naming convention until it gets too complicated...
