    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [HELP] which is the best follow-me tool?
    15 Posts 8 Posters 1.4k Views 8 Watching
      Line to tubes by Didier Bur
      from Toblerone(3) to Cylinders (12 + ) but intersections are not very completly treated! ๐Ÿ˜ฎ
      Valuable for view objects from distance ๐Ÿ˜„
      Convert arcs, lines, circles, curves to cylinders ( or Toblerone ๐Ÿ˜‰
        Followme and keep by Wikii
        • david_hD Offline
          david_h
          What about Profile Builder? Pretty cool!
            2 faces + path by Kirill2008
              And some of the Extrusion Tools = e.g. Extrude Face by Rails
              AND of course "FollowMe and Keep" too............
              • olisheaO Offline
                olishea
                OK, thanks for the response! ๐Ÿ˜
                Follow me and keep seems to be working well for my needs, although it can be inconsistent.
                I forgot about curviloft.....this produced most consistent results.....although you need to manually finish up the connection (I forgot to mention my path is in a continuous loop)
                The videos for "2 faces + path" don't work anymore....its not consistent though, unexpected results.
                TIG: You say "extrude face by rails" but I can not see this in the tool set. here is a screengrab of my extrude tools:
                sorry if I'm being stupid. your extrude tools are sweet btw, I'm just still getting my head round using them. Will make my university work so much easier! My favourite is extrude edges by rails....also extrude edges by vector....very clever (the amount of times I've wanted to push/pull a line!!!!). tell me though, why aren't these plugins for sale?? worth buying.....
                oli
                  Some examples of what profil you want propagate on what path?
                  • EdsonE Offline
                    Edson
                    do not forget 1001bit tools. in it you will find a tool that works fine every time: extrude along sloping curved path. this most useful set of tools has free and pro versions.
                    edson mahfuz, architect| porto alegre โ€ข brasil
                    http://www.mahfuz.arq.br
                    • N Offline
                      notareal
                      Wonder what happened to Kirill2008? Tutorial videos where taken down...
                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        Yes, me too. Hope he's well!
                          I meant try these...
                          Extrude Edges by Face [multiple FollowMe]
                          Extrude Edges by Faces [melds two faces along rails like FollowMe with 'morphing']
                          Extrude Edges by Rails by Face [multiple "Extrude Edges by Face" over a 'mesh' surface]
                          each of which does some 'FollowMe-like' stuff............
                          I think I am getting forgetful...
                          I think I am getting forgetful... ๐Ÿ˜‰
                          • utilerU Offline
                            utiler
                            This was a good visual example of the different outcomes, olishea.
                            followmes.skp
                            Just Curious...
                            • olisheaO Offline
                              olishea
                              thanks guys lots of great ways of doing this. TIG i think its just the names of your plugins that confuse me! not saying you should change them or anythin. i think you need a youtube series all to yourself!!
                              cheers for all the help, great forum work guys!! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                              oli
                                Know what you mean ๐Ÿ˜’
                                They confuse me too - and I made them ๐Ÿ˜•
                                The Extrusion Tools just grew like Topsy and 'EEbyXXX' originally seemed a 'sensible' naming convention until it gets too complicated...
