    Object missing..
    renderpluginsextensions
    8 Posts 4 Posters 1.1k Views 4 Watching
      claudzie
      Hi, im a semi beginner user of vray on sketchup. im making a bedroom, and i downloaded some of objects from google 3d warehouse. But there's a problem with the rendering. When I render, the bed and blanket were missing, so the pillows look like floating. I double, even triple checked, the bed and blanket seems not to be locked or hide. So does anyone know what is wrong with my bed and blanket?? 😒 😒 😒
      the bed and blanket is obviously exist
      now they are gone!
        View your SKP in Monochrome mode to see if things are 'inside out' [back-material = blue?].
        Check for layers and so on for the missing objects.
        Model Info > Statistics > Fix...
        etc
          Please post what VfSU version you are using when posting questions. There are different bugs in different versions of VfSU.
          The earlier versions did have problems at times with Groups disappearing. However, they usually appeared when you re-opened the model.
          The latest version do not have this problem.
            claudzie
            thanks, I still on v6.4, btw after I explode them it suddenly appears after rendered. I think im gonna update my version now, since I got so much troubles with the materials either.
              There is no version 6.4
              The very first had no version number
              The next had 1.00.74
              The next had 1.05.30
              The current is 1.48.89
              That's because the problem group was exploded.
                That seems to be her SU version.
                  claudzie
                  yeah, sorry i misread, i thought the sketchup version. but i just updated yesterday and now im using the lastest version, and it got so much better but there's another problem with the lighting, I saw many people made a very nice results on natural sun lighting, I even saw the youtube how to make natural sun/sky light, but I don't get it why the result didn't come out right. The shadows on the screen before it rendered seems a lot better than after it got rendered. the skylight didn't goes in my bedroom, only reach the balcony πŸ˜’ do you guys have any suggestion with the lighting?
                  before render the shadows appears to be fine
                  after render the room looks dark and there's no sunlight goes in
                    If an old scene doesn't render similar with the new version its something the ASGVis developers would like to hear about.
