    [Tutorial] PickHelper - Visual Guide
    34 Posts 11 Posters 4.4k Views 11 Watching
      When I first came across the PickHelper I was confused to exactly what data the various methods returned. I finally got around to compile a small visual guide.
      [mod=Outdated:3qctczkf]Latest version is here: http://www.thomthom.net/thoughts/2013/01/pickhelper-a-visual-guide/[/mod:3qctczkf]
      Note: this is not a complete guide of all the methods.
      What you think? Understandable?
      Print Version
      • Chris FullmerC Offline
        I'm looking it over. The first thing I see if in the top, it says "in the example to right". the example is actually to the left.
        All my Plugins I've written
          Left - Right - it's all semantics... ๐Ÿ˜’ ๐Ÿ˜ณ
          • EdsonE Offline
            Edson
            sorry, guys. you have lost me. what the heck is PickHelper???? ๐Ÿ˜ฒ
            edson mahfuz, architect| porto alegre โ€ข brasil
            http://www.mahfuz.arq.br
              You have strayed into the dark path of SketchUp API programming. ๐Ÿ˜„
              http://code.google.com/apis/sketchup/docs/ourdoc/pickhelper.html
              • EdsonE Offline
                Edson
                sorry: wrong mumber. ๐Ÿ˜‰
                  ๐Ÿคฃ
                  @Thom - I've decided I do not know enough about the pickhelper to understand this yet. I've used it, but only the best_picked method. So I've never had to worry about leafs and paths. Maybe once I get more into the pickhelper I'll have something useful to say ๐Ÿ˜›
                    Well - that means there is room for improvements. ๐Ÿ˜‰
                    Is there some parts that does make sense?
                      Sorry, but I understood it better before you published your guide ๐Ÿ˜’ ๐Ÿ˜‰
                        jessejames
                        Wow ThomThom this is a tough crowd tonight! ๐Ÿ˜ฒ. My connect speed seems to be on granny mode tonight (or your pdf is really large) but as soon as i can get an eyeall on that PDF i'll let ya know what i think ๐Ÿ˜‰
                        Always sleep with a loaded gun under your pillow!
                          Nothing to it but back to the drawing board. Think I'll make the next one bigger. Bigger is better, right? ๐Ÿ˜„
                            MartinRinehart
                            Bravo, ThomThom! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            I love it when explorers return from parts unknown bearing and sharing maps.
                            (Nit: The plural of child is children.)
                            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                              Someone understood this? ๐Ÿ˜ฎ ๐Ÿ˜„
                              Thanks - I'll sort it out for version 2. Getting a better idea on how to visualize this.
                                Revision 3
                                I've finally got around to work on a revision for this. Would you please have a look at this draft and give me your thoughts? Is it more understandable?
                                This version is more verbose and instead of trying to explain the entire class in one diagram I broke it down into categories.
                                PickHelper - Rev3 - 09-12-2013.pdf
                                • jolranJ Offline
                                  jolran
                                  I had a quick look. Good stylished job! Appears very easy too follow.
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    Text in Console Boxes a bit too small.
                                    Green bubble text 2 steps too small.
                                    Content text a bit too small.
                                    Any Ruby expressions could be in Ruby-color.
                                    Basically - too much wasted whitespace on the pages.
                                    BUT the organization looks good... a should make a nice tutorial.
                                    I'm not here much anymore.
                                      How are you viewing it? Full pagewidth? On what size monitor?
                                      Higher contrast for the code expressions would be good. But I wanted to ensure the content made any sense before I polished up the graphical details.
                                      Specifically where? The edges?
                                      I've deliberately used white space to separate the sections and divide the information into chunks so the eye is served smaller units. Hearing why you think it's too much white-space would be interesting.
                                      First of all I'm trying to gauge if the information is making sense. I want to nail the big details before I polish the small details.
                                        Did it make any sense?
                                        • jolranJ Offline
                                          jolran
                                          Yes it made sence. I love these visual guides ๐Ÿ˜„
                                          I might be a good testsubject because I have never used pickhelper.
                                          Segments and Points confused me a little, and maybe another row of explanation would not hurt.
                                          Theese following ideas may just be a subject of personal taste.
                                          (People have their way of "taking in" information visually, and it might be impossible to please everyone.)
                                          Label groups and components G1, G2 etc maybe adds 1 more level of translating information? If its for conserving space, maybe the example should include less entities.
                                          The "Test scene" picture could be a "standard style"(lightgrey) screengrab? So user feel familiar with the scene and working in SU.
                                          In any way. Great job, and thanks for doing guides like this.
                                            Expand on what "segments" and "points" are?
                                            This is something I went back and forth quite a bit with. Initially I had just plain colours, one for containers (groups and components) and one of leaves.
                                            But I felt the need to reference and identify each branch - as the order of nesting is important. I find it difficult to remove the number of entities as the test scene is specifically set up to cover a multiple of scenarios. (Several entities overlapping each other but in different context.)
                                            I agree though, it does add more noise to the chart - but without them I fear it'd be impossible to follow the flow. The Gx and Cx symbols are used to be able to reference specific entities in the descriptions.
                                            Maybe so. I set it so I'd have darker background to match more the code blocks. But maybe that's not needed. But the light grey is just one of the default templates - Engineering templates are completely different.
                                            I'll have to ponder on all this feedback.
                                            • 1 / 2
