    [Tutorial] PickHelper - Visual Guide
    34 Posts 11 Posters 4.8k Views 11 Watching
    • Chris FullmerC
      ๐Ÿคฃ
      @Thom - I've decided I do not know enough about the pickhelper to understand this yet. I've used it, but only the best_picked method. So I've never had to worry about leafs and paths. Maybe once I get more into the pickhelper I'll have something useful to say ๐Ÿ˜›
        Well - that means there is room for improvements. ๐Ÿ˜‰
        Is there some parts that does make sense?
          Sorry, but I understood it better before you published your guide ๐Ÿ˜’ ๐Ÿ˜‰
            jessejames
            Wow ThomThom this is a tough crowd tonight! ๐Ÿ˜ฒ. My connect speed seems to be on granny mode tonight (or your pdf is really large) but as soon as i can get an eyeall on that PDF i'll let ya know what i think ๐Ÿ˜‰
            Always sleep with a loaded gun under your pillow!
              Nothing to it but back to the drawing board. Think I'll make the next one bigger. Bigger is better, right? ๐Ÿ˜„
                MartinRinehart
                Bravo, ThomThom! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                I love it when explorers return from parts unknown bearing and sharing maps.
                (Nit: The plural of child is children.)
                  Someone understood this? ๐Ÿ˜ฎ ๐Ÿ˜„
                  Thanks - I'll sort it out for version 2. Getting a better idea on how to visualize this.
                    Revision 3
                    I've finally got around to work on a revision for this. Would you please have a look at this draft and give me your thoughts? Is it more understandable?
                    This version is more verbose and instead of trying to explain the entire class in one diagram I broke it down into categories.
                    PickHelper - Rev3 - 09-12-2013.pdf
                    • jolranJ
                      jolran
                      I had a quick look. Good stylished job! Appears very easy too follow.
                      • Dan RathbunD
                        Dan Rathbun
                        Text in Console Boxes a bit too small.
                        Green bubble text 2 steps too small.
                        Content text a bit too small.
                        Any Ruby expressions could be in Ruby-color.
                        Basically - too much wasted whitespace on the pages.
                        BUT the organization looks good... a should make a nice tutorial.
                        I'm not here much anymore.
                          How are you viewing it? Full pagewidth? On what size monitor?
                          Higher contrast for the code expressions would be good. But I wanted to ensure the content made any sense before I polished up the graphical details.
                          Specifically where? The edges?
                          I've deliberately used white space to separate the sections and divide the information into chunks so the eye is served smaller units. Hearing why you think it's too much white-space would be interesting.
                          First of all I'm trying to gauge if the information is making sense. I want to nail the big details before I polish the small details.
                            Did it make any sense?
                            • jolranJ
                              jolran
                              Yes it made sence. I love these visual guides ๐Ÿ˜„
                              I might be a good testsubject because I have never used pickhelper.
                              Segments and Points confused me a little, and maybe another row of explanation would not hurt.
                              Theese following ideas may just be a subject of personal taste.
                              (People have their way of "taking in" information visually, and it might be impossible to please everyone.)
                              Label groups and components G1, G2 etc maybe adds 1 more level of translating information? If its for conserving space, maybe the example should include less entities.
                              The "Test scene" picture could be a "standard style"(lightgrey) screengrab? So user feel familiar with the scene and working in SU.
                              In any way. Great job, and thanks for doing guides like this.
                                Expand on what "segments" and "points" are?
                                This is something I went back and forth quite a bit with. Initially I had just plain colours, one for containers (groups and components) and one of leaves.
                                But I felt the need to reference and identify each branch - as the order of nesting is important. I find it difficult to remove the number of entities as the test scene is specifically set up to cover a multiple of scenarios. (Several entities overlapping each other but in different context.)
                                I agree though, it does add more noise to the chart - but without them I fear it'd be impossible to follow the flow. The Gx and Cx symbols are used to be able to reference specific entities in the descriptions.
                                Maybe so. I set it so I'd have darker background to match more the code blocks. But maybe that's not needed. But the light grey is just one of the default templates - Engineering templates are completely different.
                                I'll have to ponder on all this feedback.
                                • Dan RathbunD
                                  Dan Rathbun
                                  When I click the download... Chrome d/l's it into the " %(#004040)[~/documents/downloads]" directory.
                                  I have PDF set to open in Adobe Reader (a separate process, rather than within the browser.)
                                  @thomthom said:
                                  Full pagewidth?
                                  Yes. I have Adobe Reader set to open docs in page width by default.
                                  A 20 inch diagonal, Samsung 204B (1600x1200px,) which is 16" wide by 12" high.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    That's a minor thing... don't worry too much about that now.
                                    Yep.. I find the information very easy to follow.
                                      I'll have to review the page size. To be honest - I don't know what paper size it is any more. I started out with a normal page format - but in order to focus on laying out the info I abandoned it and just expanded the page to make fit. The physical size is probably inherited by the underlying grid I used. Being vector I wasn't too concerned.
                                      Thanks for the feedback.
                                      • jolranJ
                                        jolran
                                        The last part where it says "Segments and Points". ๐Ÿ˜„
                                        It all depends on what user-level you are targeting.
                                        Me, I felt I needed more information about points. (I've never used pic helper so I'm totally green on subject.) But then again I suppose this is meant to be a visual guide with as little text as possible, so that might work against the whole concept.
                                        No need to "ponder" ๐Ÿ˜„ It is really good as it is.
                                        Got a 21 inch screen. At full screenmode and 66,7% zoom the text size was fine on my computer.
                                        Is target for print?
                                          Yea, the thing with the pickhelper is that it serves multiple purposes. It let you pick entities in the model, but it also let you test against simple Geom::Point3d object - which which isn't represented by a model entity at all. I kind of feel the class should have been broken up into two separate classes because it's currently doing two separate jobs. I have been playing with making a wrapper that might make more sense to use.
                                          No, screen was the target. Saving them poor trees.
                                            slbaumgartner
                                            @thomthom said:
                                            Revision 3
                                            Thanks TT, looks clear and helpful. Now for your next assignment, compare/contrast pickHelper and InputPoint!
                                            Steve
