    [Plugin] Scene Tweaker
    30 Posts 7 Posters 20.1k Views 7 Watching
    • AdamBA Offline
      AdamB
      This is a little Ruby plugin that simply allows you to quickly tweak the position and orientation of Scene Cameras. When generating animations, SketchUp Scenes are a great way to capture your path through your model but sometimes you don't quite get the Scenes setup right. Scene Tweaker comes to the rescue!
      Unzip the 2 files and put them in your plugins folder and restart SketchUp.
      You can start the tool from the Tools menu or the toolbar and it will show all the positions and orientations of your Scene Cameras.
      Shift+MouseClick allows you to dolly the Scene camera
      Cmd+MouseClick allows you to look through the camera and change its orientation (ie where its pointing).
      Adam
      Unzip to your plugsin folder
        Interesting.
        FYI for PC users: Cmd = Alt
        • daleD Offline
          dale
          thomthom isn't "command on a PC "ctrl"?
            Yes ... but when I tried it the plugin did not respond. I had to use Alt...
            • daleD Offline
              dale
              Just when I get used to something.....
                maxosmedia
                fakeware! doesn't work!
                TIGT 1 Reply Last reply Reply Quote -2
                  TIG Moderator @maxosmedia
                  @maxosmedia
                  It is 16 years old !
                  So SketchUp's Ruby API might have changed, and thereby made it flaky...
                  It would be helpful if you ran it with the Ruby Console open and reported any error messages - a bald statement like 'fakeware!' is no helpful...
                  Please explain the issue - it might be recoverable...
                  1 Reply Last reply πŸ‘ πŸ˜€ Reply Quote 0
                    I fixed its code to suit newer versions of SketchUp - it's in the PluginStore.
                    https://sketchucation.com/pluginstore?pln=scenetweak as v1.0, also signed [but not as an Extension per se]
                      maxosmedia
                      SU2023 the same tragic Show!
                      TIGT 1 Reply Last reply Reply Quote -1
                        @maxosmedia
                        That's not helpful.
                        How is it tragic ?
                        What happens, or what doesn't happen, etc ?
                        Did you zoom out to see the frustums etc ?
                        If you really have an issue and we can help explain it clearly so we understand...
                          maxosmedia
                          "Did you zoom out to see the frustums etc ?" - SU crash! immediately after press icon(button "scene tweak! Do you know how to read? Letters, words, sentences? deep freeze! Force quit sketchup!
                          Rich O BrienR TIGT 2 Replies Last reply Reply Quote -2
                            Rich O Brien Moderator @maxosmedia
                            He's helping. You're not by being rude
                              @maxosmedia
                              Despite your rudeness, I'll continue...
                              As I'm not sitting with you and I can indeed read, I have no idea that 'tragic' [in your language] meant that it froze/crashed.
                              Reopen SketchUp. Open the Ruby Console and try it again.
                              Is anything shown in the Console as it freezes/crashes ?
                              Is the freeze/crash creating a Bugsplat message ?
                              Have you read the info on it ?
                              Could you give us the error report parts ?
                              Have you submitted the Bugsplat to SketchUp with contact details and an explanation [in concise English] ?
                              You'll never get any help with a problem unless you give the would-be helper some clues.
                              Other info that might help...
                              SketchUp Version [2023?]
                              How many Scenes does the model have ?
                              How big is the model ?
                              Are you working in the model or in a context edit ?
                              Does it occur on every model - e.g. even a simple one with say just 2 scene tabs ?
                              Are scenes named sensibly and show on top-tab row ?
                              What's your use intention of this too ?l - it is quite niche and somewhat old/limited - and much about Scenes can be achieved by using the native tools...
                              etc
                              There's lots you can tell us that might not seem too important to you, but it might be to us.
                              • panixiaP Offline
                                panixia
                                Is there a legal way to use SU 2023 and SU 2022?
                                As far as I can tell, since 2022 they went full subscription.. and with subscription you can only install the last 3 versions (so currently 2024/25/26).
                                For this exact reason in the plugins I'm developing I'm supporting all the way down to Sketchup 2017 (which was the last free version) and I try to make sure that everything works properly up to SU 2021 (which was the last perpetual version and my favourite one). Then I test on 2024-26.
                                I personally don't give a fraction of a shit about SU 2022/2023, because they are currently available only as pirated versions.. isn't it?
                                  maxosmedia
                                  Mac osx Tahoe M1 ,SU 2026 (nulled plugins folder-only scene tweaker 1,0)
                                  SU no longer crashes, but nothing happens !
                                    maxosmedia
                                    SU no longer crashes, but nothing happens when I touch the scene markers! There is no camera frustum or any changes to the interface.Screenshot 2026-06-16 at 11.38.58.png
                                      The scene-names are displaying on screen [R-2 and entry] - but the 'frustums' are missing.
                                      You don't actually pick the 'name', which is slightly offset from the camera, you pick the root of the frustum
                                      [i.e. the camera] and move that - but because you don't have the blue frustum-root to pick it's not possible ??
                                      Note that the scenes named Top and Balcone-s might not set to remember the camera, if so then they do get skipped as they have no frustum...
                                      Have you run it with the Ruby Console open to see if there are any error messages ?
                                      If so let us see them [in full] ...
                                      As I asked before, what is your aim when using this tool ?
                                      PS: where is the green axis ? it's not visible in your screen shot.
                                      This might be down to a Graphics Card issue ?
                                      Or MacOS Tahoe not playing nice with v2026.
                                      While SketchUp v2026 officially supports macOS 26 (Tahoe), performance can be very inconsistent.
                                      Users report frequent application lock-ups (especially on Apple Silicon), a broken font panel that prevents standard text formatting, and hanging issues when loading third-party extensions ?? Do you have such issues ?
                                      M 1 Reply Last reply Reply Quote 0
                                        maxosmedia @TIG
                                        @TIG !
                                        Screenshot
                                        TIGT 1 Reply Last reply Reply Quote 0
                                          maxosmedia
                                          I haven't encountered any problems with SketchUp 2026 on my m1 Tahoe - the computer works perfectly with the program.
                                          SU log:
                                          SketchUp Version: 26.2.0242
                                          BugSplat previous log Link successful
                                          Device Manufacturer: Apple Inc.
                                                 Device Model: MacBookPro18,3
                                                   OS Version: 26.5
                                          WGLUtils::UtilsState::ctor: Max GPU perf is 0
                                          Renderer information:
                                            Graphics Engine Name: New Graphics Engine
                                            Graphics API: Metal
                                            GPU Name: Apple M1 Pro
                                          ValidateGraphicsPreferences: Starting up.
                                          SaveUserRendererSettingsToPreferences: Saving graphics preferences: MSAA: 2 FF: 1
                                          ValidateGraphicsPreferences: All done.
                                          Process Environment: Native
                                          Graphics Device: Apple M1 Pro
                                          ======== Metal GPU Family ========
                                            common1 : 1
                                            common2 : 1
                                            common3 : 1
                                            mac2 : 1
                                            apple1 : 1
                                            apple2 : 1
                                            apple3 : 1
                                            apple4 : 1
                                            apple5 : 1
                                            apple6 : 1
                                            apple7 : 1
                                          ====== End Metal GPU Family ======
                                          Activate document: ST-1
                                          Tool(SelectionTool)
                                          Start(Check Validity)Commit(1)
                                          Loaded ruby file: /Applications/SketchUp 2026/SketchUp.app/Contents/Resources/Tools/extensions.rb
                                          Loaded ruby file: /Applications/SketchUp 2026/SketchUp.app/Contents/Resources/Tools/langhandler.rb
                                          Loaded ruby file: /Applications/SketchUp 2026/SketchUp.app/Contents/Resources/Tools/sketchup.rb
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/localise.rbe
                                          Loading extension: Analysis Hub (0.2.3)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/constants.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/commands.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/session.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/attributes.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/connection_state.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/dialog.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_component_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_component_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_component_streams.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_components_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_construction_line_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_drawingelement_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_edge_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_entities_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_entities_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_entity_builder_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_entity_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_face_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_face_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_group_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_image_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_image_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_material_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_material_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_materials_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_model_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_model_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_model_selection_immediates.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_model_selection_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_operation_management.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_scene_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_scene_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_snap_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_text_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_section_plane_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_shadowinfo_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_streams.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_tag_folder_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_tag_manager_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_tag_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_tool_immediates.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_tool_streams.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_view_immediates.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/engine_view_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/optimized_search.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine/utils/image_data_url.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/engine.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/entity_filter.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/entity_builder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/id.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/message_channel_manager.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/model_cache.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/operation.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/revision_tracker.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/version.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/active_path_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/axes_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/bounds_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/camera_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/classifications_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/component_instance_change_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/load_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/callback_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/entities_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/model_options_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/model_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/model_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/operation_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/selection_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/shadowinfo_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/string_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/tool_change_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/tool_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message/view_info_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_active_path_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_attributes_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_axes_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_bounds_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_classifications_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_load_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_callback_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_camera_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_command_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_component_instance_change_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_entities_chunk_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_entities_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_entity_callback_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_entity_filter.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_immediate_command_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_instructions.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_message_protocol.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_model_chunk_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_model_operation_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_model_options_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_model_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_model_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_numeric_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_operation_command_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_query_chunker.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_query_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_selection_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_shadowinfo_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_string_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_stream_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_tool_change_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_tool_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/protocol/message-json/json_view_info_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/observers/current_model_observer.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/v2/observers/undo_buffer_overflow_observer.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/lib/habitatanalysishub.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/helpers/trimbim.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_analysis_hub/main.rbe
                                          Loaded ruby file: habitat_analysis_hub.rb
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/localise.rbe
                                          Loading extension: Add Location (1.8.2)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/clear_location.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/constants.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/su_api.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/session.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/attributes.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/connection_state.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/dialog.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_component_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_components_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_component_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_drawingelement_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_edge_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_entities_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_entities_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_entity_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_entity_builder_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_face_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_group_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_material_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_material_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_materials_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_model_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_model_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_operation_management.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_shadowinfo_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_tag_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_tag_folder_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_tag_manager_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_construction_line_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_scene_operations.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_scene_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_streams.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_view_immediates.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/engine_view_queries.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine/optimized_search.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/engine.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/entity_filter.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/entity_builder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/id.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/message_channel_manager.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/model_cache.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/operation.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/revision_tracker.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/version.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/axes_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/bounds_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/camera_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/classifications_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/load_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/callback_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/entities_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/model_options_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/model_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/model_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/operation_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/shadowinfo_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/string_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message/view_info_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_attributes_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_axes_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_bounds_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_classifications_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_load_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_callback_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_camera_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_command_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_entities_chunk_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_entities_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_entity_callback_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_entity_filter.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_immediate_command_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_instructions.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_message_protocol.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_model_chunk_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_model_operation_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_model_options_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_model_query_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_model_stream_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_numeric_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_operation_command_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_query_chunker.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_query_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_shadowinfo_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_string_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_stream_type.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/protocol/message-json/json_view_info_encoder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/observers/current_model_observer.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/v2/observers/undo_buffer_overflow_observer.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/lib/habitatsitecontext.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/observers/model_change_observer.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/site_context_overlay.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/habitat_site_context/main.rbe
                                          Loaded ruby file: habitat_site_context.rb
                                          Loading extension: AI Assistant (1.0.3)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/dos_time.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/ioextras/abstract_input_stream.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/ioextras/abstract_output_stream.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/ioextras.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/entry.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field/generic.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field/universal_time.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field/old_unix.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field/unix.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field/zip64.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field/zip64_placeholder.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/extra_field.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/entry_set.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/central_directory.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/file.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/input_stream.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/output_stream.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/decompressor.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/compressor.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/null_decompressor.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/null_compressor.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/null_input_stream.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/pass_thru_compressor.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/pass_thru_decompressor.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/inflater.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/deflater.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/streamable_stream.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/streamable_directory.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/constants.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip/errors.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/rubyzip/zip.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/su_assistant_root.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/generate_assets_agent.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/generate_spaces_agent.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/generate_wall_agent.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/generate_mesh_agent.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/tools_executor_agent.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/create_extension_agent.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/sketchup_parser.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/rb/sketchup_viewport_utils.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_assistant/su_assistant_root_proxy.rbe
                                          Loaded ruby file: su_assistant.rb
                                          Loading extension: AI Render (1.2026.03.25)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_diffusion/ruby/update_scene.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_diffusion/ruby/susdana.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_diffusion/ruby/susdroot.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_diffusion/ruby/susdrootproxy.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_diffusion/su_loader.rbe
                                          Loaded ruby file: su_diffusion.rb
                                          Loading extension: Dynamic Components (1.8.5)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/generatereport.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe
                                          Loaded ruby file: su_dynamiccomponents.rb
                                          Loading extension: Migrate Extensions (1.0.2)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/plugin_folders.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/simple_ruby_parser.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/extension_info.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/extension_migration_job.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/sketchup_preferences.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/extension_migration_queue.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/analytics.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/dialog.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/auto_prompt.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_extension_migrator/main.rbe
                                          Loaded ruby file: su_extension_migrator.rb
                                          Loading extension: Sandbox Tools (2.3.5)
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/geometryhelpers.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/meshhelpers.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/triangulatorutility.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/fromcontours.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/fromscratch.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/smoovetool.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/stamptool.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/drapetool2.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/detailtool.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/flipedgetool.rbe
                                          Loaded ruby file: /users/maxos/library/application support/sketchup 2026/sketchup/plugins/su_sandbox/sandboxmenus.rbe
                                          Loaded ruby file: su_sandbox.rb
                                          Loaded ruby file: /Users/maxos/Library/Application Support/SketchUp 2026/SketchUp/Plugins/scenetweak.rb
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Start(Macro)Undo(Scene Internal)
                                          Tool(RubyTool)
                                          Tool(CameraOrbitTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(CameraFOVTool)
                                          Start(Check Validity)Commit(15)
                                          File Save
                                          Tool(CameraFOVTool)
                                          Start(Check Validity)Commit(16)
                                          File Save
                                          Tool(RubyTool)
                                          Tool(PositionCameraTool)
                                          Tool(CameraPanTool)
                                          Start(Add Scene)Commit(17)
                                          Start(Rename Scene)Commit(18)
                                          Start(Rename Scene)Commit(19)
                                          Tool(SelectionTool)
                                          Start(Check Validity)Commit(20)
                                          File Save
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Tool(RubyTool)
                                          Start(Update Scene)Commit(26)
                                          Start(Rename Scene)Commit(27)
                                          Start(Update Scene)Commit(28)
                                          Start(Update Scene)Commit(29)
                                          Start(Check Validity)Commit(30)
                                          File Save
                                          Start(Check Validity)Commit(31)
                                          File Save
                                          Start(Update Scene)Commit(32)
                                          Start(Check Validity)Commit(33)
                                          File Save
                                          Start(Update Scene)Commit(34)
                                          Tool(RubyTool)
                                            maxosmedia
                                            Advanced Camera Tools screenshots. all camera frustums is here.
                                            • 2 / 2
