[Plugin] Scene Tweaker
This is a little Ruby plugin that simply allows you to quickly tweak the position and orientation of Scene Cameras. When generating animations, SketchUp Scenes are a great way to capture your path through your model but sometimes you don't quite get the Scenes setup right. Scene Tweaker comes to the rescue!
[flash=600,338:3eo5s7u1]http://www.youtube.com/v/jBT-mNg2Yck[/flash:3eo5s7u1]
Unzip the 2 files and put them in your plugins folder and restart SketchUp.
You can start the tool from the Tools menu or the toolbar and it will show all the positions and orientations of your Scene Cameras.
Shift+MouseClick allows you to dolly the Scene camera
Cmd+MouseClick allows you to look through the camera and change its orientation (ie where its pointing).
Adam
Interesting.
FYI for PC users: Cmd = Alt
thomthom isn't "command on a PC "ctrl"?
Yes ... but when I tried it the plugin did not respond. I had to use Alt...
Just when I get used to something.....
fakeware! doesn't work!
@maxosmedia
It is 16 years old !
So SketchUp's Ruby API might have changed, and thereby made it flaky...
It would be helpful if you ran it with the Ruby Console open and reported any error messages - a bald statement like 'fakeware!' is no helpful...
Please explain the issue - it might be recoverable... -
I fixed its code to suit newer versions of SketchUp - it's in the PluginStore.
https://sketchucation.com/pluginstore?pln=scenetweak as v1.0, also signed [but not as an Extension per se]
