    Window Help!
    7 Posts 3 Posters 1.1k Views 3 Watching
    • D
      Dragoonprogramming
      I am In the process of geo-modeling a house but I am having trouble with some windows
      In the back of the house There are two windows that I drew
      However when I go to put the translucent texture on them it does this:
      for whatever reason it does not recognise this as a face
      I have tried everything please help!
      And for those who are wondering: this is a geo model, and I am trying to keep it simple so I wont be using a component window.
      "...And if he says that one more time i'll punch him right in the throat" - Armstrong and Getty
      My website http://dragoonprogramming.weebly.com/
      • D
        Dragoonprogramming
        And yes the are perfect squares no openings at al
          Looks like your geometry isn't intersecting with the house. Which can happen for lots of reasons. Could you upload your model so we can look?
          • D
            Dragoonprogramming
            here it is
            Avery Home.skp
            Go nuts πŸ˜„
            Thanks for the help
            • TIGT
              The gable end isn't quite vertical so the window rectangles are not on its surface.
              Remake the wall using the inference tools and axis locks to set it vertically and retry with the windows...
                Take TIG's advice and learn how to use the inferencing engine in SU. Your model was really out of alignment(non-co-planar) and had lots of other little issues.
                Here's a quick version of just the house for you too now apply materials and windows etc. It has been 'Grouped' so double click it with the select tool to edit it.
                Avery Home.skp
                You can find out about 'Groups/Components' in the Google Help Forums. Just choose 'Help' from the menu bar
                • D
                  Dragoonprogramming
                  thanks guys this was one of my first geo model and got around to asking about the windows πŸ˜‰
                  Realy helpful!
