    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 42.0k Views 22 Watching
      sahi
      @daniel s said:
      Sahi, thanks again...
      I was trying your plugin... and discover a new issue.. but this one is very important
      I put 60ΒΊ in the protractor but the result is 59,38ΒΊ for example.
      Fixed
      Upgrade plugins First Message Brick_6.zip
        tomislavm
        Thanks!
        • urgenU Offline
          urgen
          Ooo very useful! πŸŽ‰ thanks! πŸ‘
          --pupil forever...------
            sahi
            Upgrade plugins First Message Brick_7.zip
              sahi
              Upgrade plugins First Message Brick_8.zip
              • utilerU Offline
                utiler
                @daniel s said:
                Thank you Sahi!!!
                A great plugin!!!
                http://www.sketchup8.com.ar/2010/08/copy-brick-plugin.html
                Daniel S
                Off topic:
                Daniel, I've had a look at your blog, follwoing it now!!! Just curious, why Sketchup8.com.ar? WHat happens when V8.0 is out and V9.0 is next? πŸ˜‰
                Just Curious...
                  Daniel S
                  @utiler said:
                  Off topic:
                  The domain names in Argentina are .com.ar
                  And the 8 will be changed for ∞ using the future SU 9.0 technology:
                  sketchup8.com.ar.gif πŸ˜› πŸ˜› πŸ˜›
                  Daniel S
                  • utilerU Offline
                    utiler
                    Clever boy! look forward to following.... πŸ‘
                    Just Curious...
                    • N Offline
                      njh
                      Hi Sahi / Guys,
                      Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
                      The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
                      Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
                      Hope someone can help.
                      Cheers
                      NJH
                      • N Offline
                        njh
                        Hi Sahi,
                        Fast comeback!
                        Just downloaded the "brick 9" update and now the ctrl key does nothing. Was that the plan?
                        The mirror buttons at the top of the screen work but the object goes off screen during the mirror process so it is not as intuitive to use and not as obvious to see what what is happening to the object during the mirror.
                        Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
                        Cheers
                        NJH
                          sahi
                          What are the keys you are free ????
                          What are the keys create one??
                            sahi
                            @njh said:
                            Hi Sahi / Guys,
                            test
                            • N Offline
                              njh
                              Sorry - I don't understand your last response.
                              What I was originally trying to say was the keyboard shortcuts shown on your keyboard picture for "home" and "end" don't appear on an apple keyboard and I can't / don't know how to re-map the shortcut for those commands within your plugin in preferences/shortcuts.
                              Cheers
                              NJH
                                sahi
                                Key
                                A - ??
                                B - ??
                                C - ??
                                What are the keys to choose ?
                                • N Offline
                                  njh
                                  Hi Sahi,
                                  Thanks or your patience.
                                  I can get to the shortcut menu like you show but I can't locate your plugin tools in the "function" list. The only item listed is to view the Brick pallett. Thats my problem.
                                    sahi
                                    @njh said:
                                    Hi Sahi,
                                    NO no no......
                                    Keys "1" >> mirror red axis
                                    Keys "2" >> mirror green axis
                                    Keys "3" >> mirror blue axis
                                    Brick_10.zip
                                    • N Offline
                                      njh
                                      Thank you, thank you, thank you..............
                                      Works fine with Brick 10 now.
                                      Great plugin!
                                      Cheers
                                      NJH
                                      • kenK Offline
                                        ken
                                        Is one ever satisfied?
                                        Your mirror does mirror, however this to me is more like a "flip", an actual mirror should also be able to copy the selection.
                                        So would that be possible? And if not, I will be pleased that so many people take the time to add improvement to Sketchup and their plugins.
                                        Again, thank you
                                        Ken
                                          sahi
                                          NJH
                                            Ben Ritter
                                            First off, thank you for the script and for sharing.
                                            Second, I cannot get the mirror function to work. Any suggestions?
                                            Third, can this work on SU 6?
                                            Thanks. Ben
                                            • 2 / 4
