    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 57.1k Views 22 Watching
      Daniel S
      @utiler said:
      Off topic:
      Daniel, I've had a look at your blog, follwoing it now!!! Just curious, why Sketchup8.com.ar? WHat happens when V8.0 is out and V9.0 is next? πŸ˜‰
      The domain names in Argentina are .com.ar
      And the 8 will be changed for ∞ using the future SU 9.0 technology:
      sketchup8.com.ar.gif πŸ˜› πŸ˜› πŸ˜›
      Daniel S
      • utilerU Offline
        utiler
        Clever boy! look forward to following.... πŸ‘
        Just Curious...
        • N Offline
          njh
          Hi Sahi / Guys,
          Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
          The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
          Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
          Hope someone can help.
          Cheers
          NJH
          • N Offline
            njh
            Hi Sahi,
            Fast comeback!
            Just downloaded the "brick 9" update and now the ctrl key does nothing. Was that the plan?
            The mirror buttons at the top of the screen work but the object goes off screen during the mirror process so it is not as intuitive to use and not as obvious to see what what is happening to the object during the mirror.
            Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
            Cheers
            NJH
              sahi
              What are the keys you are free ????
              What are the keys create one??
                sahi
                @njh said:
                Hi Sahi / Guys,
                test
                • N Offline
                  njh
                  Sorry - I don't understand your last response.
                  What I was originally trying to say was the keyboard shortcuts shown on your keyboard picture for "home" and "end" don't appear on an apple keyboard and I can't / don't know how to re-map the shortcut for those commands within your plugin in preferences/shortcuts.
                  Cheers
                  NJH
                    sahi
                    Key
                    A - ??
                    B - ??
                    C - ??
                    What are the keys to choose ?
                    • N Offline
                      njh
                      Hi Sahi,
                      Thanks or your patience.
                      I can get to the shortcut menu like you show but I can't locate your plugin tools in the "function" list. The only item listed is to view the Brick pallett. Thats my problem.
                        sahi
                        @njh said:
                        Hi Sahi,
                        NO no no......
                        Keys "1" >> mirror red axis
                        Keys "2" >> mirror green axis
                        Keys "3" >> mirror blue axis
                        Brick_10.zip
                        • N Offline
                          njh
                          Thank you, thank you, thank you..............
                          Works fine with Brick 10 now.
                          Great plugin!
                          Cheers
                          NJH
                          • kenK Offline
                            ken
                            Is one ever satisfied?
                            Your mirror does mirror, however this to me is more like a "flip", an actual mirror should also be able to copy the selection.
                            So would that be possible? And if not, I will be pleased that so many people take the time to add improvement to Sketchup and their plugins.
                            Again, thank you
                            Ken
                              sahi
                              NJH
                                Ben Ritter
                                First off, thank you for the script and for sharing.
                                Second, I cannot get the mirror function to work. Any suggestions?
                                Third, can this work on SU 6?
                                Thanks. Ben
                                  sahi
                                      **Brick_8.zip**
                                  Keys "Ctrl" >> mirror red axis
                                  Keys "Home" >> mirror green axis
                                  Keys "End" >> mirror blue axis
                                     **Brick_10.zip**
                                   **Brick_9.zip**
                                  mirror administrated mouse
                                  Yes.
                                  and SU 7 and SU 6 and SU 5
                                  • N Offline
                                    Nick2010
                                    Thanks for this Plugin. i like the rotate tools!
                                      Daniel S
                                      Thank you Sahi!!!
                                      A great plugin!!!
                                      http://www.sketching3d.com.ar/2010/08/copy-brick-plugin.html
                                      Daniel S
                                        SUFractal
                                        Why doesn't this plug-in download as a .rb file?
                                        It downloads as a .rbs file and does not seem to open or operate properly?
                                          It's an encrypted rb file. The author may not wish to reveal the code. It works just like a simple rb file however.
                                            SUFractal
                                            Hmmmmmm. That's understandable, but I have the ruby placed properly, but do not see for the life of me the "tool" anywhere w/in SU?
                                            What/where should I be looking?
                                            Thanks.
                                            • 2 / 4
