    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 56.4k Views 22 Watching
      sahi
      Upgrade plugins First Message Brick_7.zip
        sahi
        Upgrade plugins First Message Brick_8.zip
        • utilerU Offline
          utiler
          @daniel s said:
          Thank you Sahi!!!
          A great plugin!!!
          http://www.sketchup8.com.ar/2010/08/copy-brick-plugin.html
          Daniel S
          Off topic:
          Daniel, I've had a look at your blog, follwoing it now!!! Just curious, why Sketchup8.com.ar? WHat happens when V8.0 is out and V9.0 is next? πŸ˜‰
          Just Curious...
            Daniel S
            @utiler said:
            Off topic:
            The domain names in Argentina are .com.ar
            And the 8 will be changed for ∞ using the future SU 9.0 technology:
            sketchup8.com.ar.gif πŸ˜› πŸ˜› πŸ˜›
            Daniel S
            • utilerU Offline
              utiler
              Clever boy! look forward to following.... πŸ‘
              Just Curious...
              • N Offline
                njh
                Hi Sahi / Guys,
                Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
                The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
                Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
                Hope someone can help.
                Cheers
                NJH
                • N Offline
                  njh
                  Hi Sahi,
                  Fast comeback!
                  Just downloaded the "brick 9" update and now the ctrl key does nothing. Was that the plan?
                  The mirror buttons at the top of the screen work but the object goes off screen during the mirror process so it is not as intuitive to use and not as obvious to see what what is happening to the object during the mirror.
                  Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
                  Cheers
                  NJH
                    sahi
                    What are the keys you are free ????
                    What are the keys create one??
                      sahi
                      @njh said:
                      Hi Sahi / Guys,
                      test
                      • N Offline
                        njh
                        Sorry - I don't understand your last response.
                        What I was originally trying to say was the keyboard shortcuts shown on your keyboard picture for "home" and "end" don't appear on an apple keyboard and I can't / don't know how to re-map the shortcut for those commands within your plugin in preferences/shortcuts.
                        Cheers
                        NJH
                          sahi
                          Key
                          A - ??
                          B - ??
                          C - ??
                          What are the keys to choose ?
                          • N Offline
                            njh
                            Hi Sahi,
                            Thanks or your patience.
                            I can get to the shortcut menu like you show but I can't locate your plugin tools in the "function" list. The only item listed is to view the Brick pallett. Thats my problem.
                              sahi
                              @njh said:
                              Hi Sahi,
                              NO no no......
                              Keys "1" >> mirror red axis
                              Keys "2" >> mirror green axis
                              Keys "3" >> mirror blue axis
                              Brick_10.zip
                              • N Offline
                                njh
                                Thank you, thank you, thank you..............
                                Works fine with Brick 10 now.
                                Great plugin!
                                Cheers
                                NJH
                                • kenK Offline
                                  ken
                                  Is one ever satisfied?
                                  Your mirror does mirror, however this to me is more like a "flip", an actual mirror should also be able to copy the selection.
                                  So would that be possible? And if not, I will be pleased that so many people take the time to add improvement to Sketchup and their plugins.
                                  Again, thank you
                                  Ken
                                    sahi
                                    NJH
                                      Ben Ritter
                                      First off, thank you for the script and for sharing.
                                      Second, I cannot get the mirror function to work. Any suggestions?
                                      Third, can this work on SU 6?
                                      Thanks. Ben
                                        sahi
                                            **Brick_8.zip**
                                        Keys "Ctrl" >> mirror red axis
                                        Keys "Home" >> mirror green axis
                                        Keys "End" >> mirror blue axis
                                           **Brick_10.zip**
                                         **Brick_9.zip**
                                        mirror administrated mouse
                                        Yes.
                                        and SU 7 and SU 6 and SU 5
                                        • N Offline
                                          Nick2010
                                          Thanks for this Plugin. i like the rotate tools!
                                            Daniel S
                                            Thank you Sahi!!!
                                            A great plugin!!!
                                            http://www.sketching3d.com.ar/2010/08/copy-brick-plugin.html
                                            Daniel S
                                            • 2 / 4
