    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 78.5k Views 22 Watching
    • N
      njh
      Hi Sahi / Guys,
      Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
      The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
      Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
      Hope someone can help.
      Cheers
      NJH
      • N
        njh
        Hi Sahi,
        Fast comeback!
        Just downloaded the "brick 9" update and now the ctrl key does nothing. Was that the plan?
        The mirror buttons at the top of the screen work but the object goes off screen during the mirror process so it is not as intuitive to use and not as obvious to see what what is happening to the object during the mirror.
        Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
        Cheers
        NJH
          sahi
          What are the keys you are free ????
          What are the keys create one??
            sahi
            @njh said:
            Hi Sahi / Guys,
            test
            • N
              njh
              Sorry - I don't understand your last response.
              What I was originally trying to say was the keyboard shortcuts shown on your keyboard picture for "home" and "end" don't appear on an apple keyboard and I can't / don't know how to re-map the shortcut for those commands within your plugin in preferences/shortcuts.
              Cheers
              NJH
                sahi
                Key
                A - ??
                B - ??
                C - ??
                What are the keys to choose ?
                • N
                  njh
                  Hi Sahi,
                  Thanks or your patience.
                  I can get to the shortcut menu like you show but I can't locate your plugin tools in the "function" list. The only item listed is to view the Brick pallett. Thats my problem.
                    sahi
                    @njh said:
                    Hi Sahi,
                    NO no no......
                    Keys "1" >> mirror red axis
                    Keys "2" >> mirror green axis
                    Keys "3" >> mirror blue axis
                    Brick_10.zip
                    • N
                      njh
                      Thank you, thank you, thank you..............
                      Works fine with Brick 10 now.
                      Great plugin!
                      Cheers
                      NJH
                      • kenK
                        ken
                        Is one ever satisfied?
                        Your mirror does mirror, however this to me is more like a "flip", an actual mirror should also be able to copy the selection.
                        So would that be possible? And if not, I will be pleased that so many people take the time to add improvement to Sketchup and their plugins.
                        Again, thank you
                        Ken
                          sahi
                          NJH
                          • B
                            Ben Ritter
                            First off, thank you for the script and for sharing.
                            Second, I cannot get the mirror function to work. Any suggestions?
                            Third, can this work on SU 6?
                            Thanks. Ben
                              sahi
                                  **Brick_8.zip**
                              Keys "Ctrl" >> mirror red axis
                              Keys "Home" >> mirror green axis
                              Keys "End" >> mirror blue axis
                                 **Brick_10.zip**
                               **Brick_9.zip**
                              mirror administrated mouse
                              Yes.
                              and SU 7 and SU 6 and SU 5
                              • N
                                Nick2010
                                Thanks for this Plugin. i like the rotate tools!
                                  Daniel S
                                  Thank you Sahi!!!
                                  A great plugin!!!
                                  http://www.sketching3d.com.ar/2010/08/copy-brick-plugin.html
                                  Daniel S
                                    SUFractal
                                    Why doesn't this plug-in download as a .rb file?
                                    It downloads as a .rbs file and does not seem to open or operate properly?
                                    • GaieusG
                                      It's an encrypted rb file. The author may not wish to reveal the code. It works just like a simple rb file however.
                                        SUFractal
                                        Hmmmmmm. That's understandable, but I have the ruby placed properly, but do not see for the life of me the "tool" anywhere w/in SU?
                                        What/where should I be looking?
                                        Thanks.
                                        • cmeedC
                                          cmeed
                                          I'm having trouble finding the mirror functions and short cuts
                                          I have downloaded brick14
                                          on a mac
                                          one of the pictures before has three coloured axis squares at the top and bottom of the rotate protractor where i only have them at the bottom.
                                          i can't also get any of the short cuts to work, i saw an earlier post answering a mac question to this but i can't seem to get it to work.
                                          I press 1,2,3 nothing happens, i have nothing assigned to these keys, nothing other than what the previous post highlighted is in my shortcuts - view brick pallette
                                          any help
                                          (do i need to download brick 10? which is not the latest version?)
                                          • T
                                            tfdesign
                                            Pardon my ignorance, but I'm trying to see how this plugin improves on the tools already available in SketchUp for adding copying and rotating. What I was really hoping to see was a wall creation tool, where you define the number of bricks needed, and at what dimension in h,w and d, then the height and width of the wall. But it seems that this plug-in doesn't do that? Or does it? Or am I just missing the plot altogether? πŸ˜•
                                            I'd also very much like to see a plugin that randomly chooses textures from a predefined texture pool (folder). This would mean that the wall would at least have some sort of irregularity to it, rather than each brick just looking the same. Is that doable?
                                            best,
                                            Tom
                                            • 2 / 4
