    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 78.5k Views 22 Watching
    • utilerU
      utiler
      @daniel s said:
      Thank you Sahi!!!
      A great plugin!!!
      http://www.sketchup8.com.ar/2010/08/copy-brick-plugin.html
      Daniel S
      Off topic:
      Daniel, I've had a look at your blog, follwoing it now!!! Just curious, why Sketchup8.com.ar? WHat happens when V8.0 is out and V9.0 is next? πŸ˜‰
      Just Curious...
        Daniel S
        @utiler said:
        Off topic:
        The domain names in Argentina are .com.ar
        And the 8 will be changed for ∞ using the future SU 9.0 technology:
        sketchup8.com.ar.gif πŸ˜› πŸ˜› πŸ˜›
        Daniel S
        • utilerU
          utiler
          Clever boy! look forward to following.... πŸ‘
          Just Curious...
          • N
            njh
            Hi Sahi / Guys,
            Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
            The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
            Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
            Hope someone can help.
            Cheers
            NJH
            • N
              njh
              Hi Sahi,
              Fast comeback!
              Just downloaded the "brick 9" update and now the ctrl key does nothing. Was that the plan?
              The mirror buttons at the top of the screen work but the object goes off screen during the mirror process so it is not as intuitive to use and not as obvious to see what what is happening to the object during the mirror.
              Using the keyboard shortcut (even though I could only get one working) was much easier to get the desired result.
              Cheers
              NJH
                sahi
                What are the keys you are free ????
                What are the keys create one??
                  sahi
                  @njh said:
                  Hi Sahi / Guys,
                  test
                  • N
                    njh
                    Sorry - I don't understand your last response.
                    What I was originally trying to say was the keyboard shortcuts shown on your keyboard picture for "home" and "end" don't appear on an apple keyboard and I can't / don't know how to re-map the shortcut for those commands within your plugin in preferences/shortcuts.
                    Cheers
                    NJH
                      sahi
                      Key
                      A - ??
                      B - ??
                      C - ??
                      What are the keys to choose ?
                      • N
                        njh
                        Hi Sahi,
                        Thanks or your patience.
                        I can get to the shortcut menu like you show but I can't locate your plugin tools in the "function" list. The only item listed is to view the Brick pallett. Thats my problem.
                          sahi
                          @njh said:
                          Hi Sahi,
                          NO no no......
                          Keys "1" >> mirror red axis
                          Keys "2" >> mirror green axis
                          Keys "3" >> mirror blue axis
                          Brick_10.zip
                          • N
                            njh
                            Thank you, thank you, thank you..............
                            Works fine with Brick 10 now.
                            Great plugin!
                            Cheers
                            NJH
                            • kenK
                              ken
                              Is one ever satisfied?
                              Your mirror does mirror, however this to me is more like a "flip", an actual mirror should also be able to copy the selection.
                              So would that be possible? And if not, I will be pleased that so many people take the time to add improvement to Sketchup and their plugins.
                              Again, thank you
                              Ken
                                sahi
                                NJH
                                • B
                                  Ben Ritter
                                  First off, thank you for the script and for sharing.
                                  Second, I cannot get the mirror function to work. Any suggestions?
                                  Third, can this work on SU 6?
                                  Thanks. Ben
                                    sahi
                                        **Brick_8.zip**
                                    Keys "Ctrl" >> mirror red axis
                                    Keys "Home" >> mirror green axis
                                    Keys "End" >> mirror blue axis
                                       **Brick_10.zip**
                                     **Brick_9.zip**
                                    mirror administrated mouse
                                    Yes.
                                    and SU 7 and SU 6 and SU 5
                                    • N
                                      Nick2010
                                      Thanks for this Plugin. i like the rotate tools!
                                        Daniel S
                                        Thank you Sahi!!!
                                        A great plugin!!!
                                        http://www.sketching3d.com.ar/2010/08/copy-brick-plugin.html
                                        Daniel S
                                          SUFractal
                                          Why doesn't this plug-in download as a .rb file?
                                          It downloads as a .rbs file and does not seem to open or operate properly?
                                          • GaieusG
                                            It's an encrypted rb file. The author may not wish to reveal the code. It works just like a simple rb file however.
                                            • 2 / 4
