    Continuous insert component
    15 Posts 5 Posters 2.1k Views 5 Watching
    • D
      dedmin
      Is there a plugin like this
        Chris Fullmer's Repeat Copy maybe? It doesn't have the same interface but allows you to preselect a component and then click to place with added options for scaling or rotating between values.
        That's a long sentence!
        • thomthomT
          Isn't video from SketchUp..?
          • D
            dedmin
            Thanks!
            • D
              dedmin
              Yes. This is the freeware plugin ProjectSketch - http://www.renderplus.com/wk/ProjectSketch_-_Tutorial_w.htm
              But it doesn't use "Glue to" to place a component and is useless.
              • thomthomT
                Glue to is a property of the Component Definition. You need to set this property for a component to glue to anything.
                • D
                  dedmin
                  Yes it is set. But ProjectSketch has own settings for placement
                    Would Chris' script fulfil your needs? I think he has a similar script which doesn't have the scale or rotate function and it's free.
                    But I recommend Repeat Copy as it is a great tool!
                    • D
                      dedmin
                      Yes, it would be great - I just need a simple plugin to paste multiple copies of a component - nothing more and fancy. But I cannot find it!
                        Repeat Copy is found on Smustard.....Here's the thread with a video
                        I was wrong about the free version 😳
                        • D
                          dedmin
                          No, I mean cannot find the simple one 🀣
                            I got confuddled! He's other version scales and rotates. Looks like you'll have to get the check book out!
                            • X
                              xrok1
                              simply click back and forth between model and comp browser! πŸ˜’
                              β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                              • D
                                dedmin
                                Too simple ... πŸ’š
                                • T
                                  thonsy
                                  hey guys,can u help me.where should i download components stringer plugins?
