    Continuous insert component
    15 Posts 5 Posters 2.1k Views 5 Watching
      Chris Fullmer's Repeat Copy maybe? It doesn't have the same interface but allows you to preselect a component and then click to place with added options for scaling or rotating between values.
      That's a long sentence!
        @dedmin said:
        Is there a plugin like this
        Isn't video from SketchUp..?
          dedmin
            dedmin
            Yes. This is the freeware plugin ProjectSketch - http://www.renderplus.com/wk/ProjectSketch_-_Tutorial_w.htm
            But it doesn't use "Glue to" to place a component and is useless.
              Glue to is a property of the Component Definition. You need to set this property for a component to glue to anything.
                dedmin
                Yes it is set. But ProjectSketch has own settings for placement
                  Would Chris' script fulfil your needs? I think he has a similar script which doesn't have the scale or rotate function and it's free.
                  But I recommend Repeat Copy as it is a great tool!
                    dedmin
                    Yes, it would be great - I just need a simple plugin to paste multiple copies of a component - nothing more and fancy. But I cannot find it!
                      Repeat Copy is found on Smustard.....Here's the thread with a video
                      I was wrong about the free version 😳
                        dedmin
                        No, I mean cannot find the simple one 🀣
                          I got confuddled! He's other version scales and rotates. Looks like you'll have to get the check book out!
                          • X
                            xrok1
                            simply click back and forth between model and comp browser! πŸ˜’
                              dedmin
                              Too simple ... πŸ’š
                              • T
                                thonsy
                                hey guys,can u help me.where should i download components stringer plugins?
