    DC SpiralStairCaseBuilder
    11 Posts 5 Posters 10.0k Views 5 Watching
    • H Offline
      Howard leslie
      SpiralStairCaseBuilder – General Notes
      1. SpiralStairCaseBuilder – A Dynamic Component that can be used to help model Spiral and Helical Staircases very quickly.
      2. Similar in style and operation to another related Dynamic Component – StairCaseBuilder.
        See http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
      NOTE:
      Dynamic Components can be USED by ALL SketchUp Users - Free & Pro
      Release Log
      V4 (Current Version) - 2010-07-10 first public release.
      SpiralStairCaseBuilder Dialog Box
      TOP TIPS (See attached PDF User Guide also)
      HANDRAILING
      Finished Spiral Staircase
      1. Handrail Construction Guides have been added. The SpiralStairCaseBuilder has simple lines that can be used as guides to help model more detailed handrailing for your staircase if required. (Similar to StairCaseBuilder).
      2. The Handrail Construction Guides (lines) should be set up to approximate / help you visualise the actual handrails and balustrades (verticals) you require. (If you don't need them, then just turn the layer off).
        Up to 4 Handrail Guides (horizontal lines) can be added.
      3. Don't overdetail the handrailing / verticals if they are never viewed really close up eg use a 12 or 16 sided circle for round sections etc or use rectangular sections. To help model more detailed handrailing, I can thoroughly recommend use of the following plug-ins:
      Bezier Spline (Fredo)
      Pipe Along Path (TIG)
      Profile Builder (Dale Martens)
      Any probs / suggestions / improvements / feedback etc - giz a shout
      Enjoy
      Howard L'
      Keywords: Dynamic Component DC Spiral Staircase Stairs Steps
      SpiralStairCaseBuilder_V4_UserGuide_Zipd.pdf
      DC_SpiralStairCaseBuilder_V4.skp
        dylan
        Looks like a really good idea Howard. Spiral staircases are always popular and can be tricky to model.
        Can't use it myself, not a Pro user but I'm sure it will be well received.
        http://dmdarchitecture.co.uk/
        • H Offline
          Howard leslie
          Dylan,
          You can use it !!!
          View - Toolbars - Dynamic Components
          Then use the Yellow Icon - Component Options
          ALL SketchUp users can USE Dynamic Components.
          Only PRO users can CREATE them.
          Hope this helps
          Howard L'
            dylan
            Thanks for the info Howard, I had completely forgot about that due to never experimenting with DC's.
            I had a play around with this and it works perfectly. Very useful, thank you.
            • EdsonE Offline
              Edson
              howard,
              would your DC be able to build something like the stair attached here?red_heli_stair.png
              http://www.mahfuz.arq.br
              • charly2008C Offline
                charly2008
                Hi Howard,
                This component has certainly made a lot of work. But I find it a bit difficult to control because of the many parameters. I prefer the tool "Grow" for spiral stairs. So I can devote myself to the design of a single step and the handrail.
                I transform this into a component and then only needs to calculate the number of steps in the height and the number of turns.
                Charly
                • H Offline
                  Howard leslie
                  Edson,
                  See attached.
                  A very brief Tutorial put together quickly.
                  Its to show the principle more than anything else.
                  Hope this helps
                  Bye
                  Howard L'
                  DC_SpiralStairCaseBuilder_V4 Solid_Balustrade_Example.zip
                  • EdsonE Offline
                    Edson
                    hi howard,
                    thanks for taking the trouble to produce a tutorial. it certainly helps.
                    regards.
                    edson
                    • EdsonE Offline
                      Edson
                      thanks, howard! 😄
                      • H Offline
                        Howard leslie
                        Edson,
                        See attached *.skp
                        A more complete (better) example of a spiral staircase with solid balustrades.
                        (As opposed to the example shown in the tutorial above that was created very quickly)
                        Spiral Staircase with Solid Balustrade
                        See first example (above) for the method.
                        This is made exactly the same way.
                        1. Adjust Staircase variables, click Apply
                        2. Create Balustrades
                        3. Thicken up Balustrades, increase step width to hide slight gaps if reqd
                        4. Add solid risers if reqd
                        5. Adjust steps if reqd
                          Quite quick to create (approx 10 mins)
                          Enjoy
                          Howard L'
                        DC_SpiralStairCaseBuilder_V4_Solid-Balustrade-Example2.zip
                        • pyrolunaP Offline
                          pyroluna
                          👍 Like +1
