πŸ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
DC SpiralStairCaseBuilder
Scheduled Pinned Locked Moved Dynamic Components
11 Posts 5 Posters 9.4k Views 5 Watching
  • H Offline
    Howard leslie
    SpiralStairCaseBuilder – General Notes
    1. SpiralStairCaseBuilder – A Dynamic Component that can be used to help model Spiral and Helical Staircases very quickly.
    2. Similar in style and operation to another related Dynamic Component – StairCaseBuilder.
      See http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
    NOTE:
    Dynamic Components can be USED by ALL SketchUp Users - Free & Pro
    Release Log
    V4 (Current Version) - 2010-07-10 first public release.
    SpiralStairCaseBuilder Dialog Box
    TOP TIPS (See attached PDF User Guide also)
    HANDRAILING
    Finished Spiral Staircase
    1. Handrail Construction Guides have been added. The SpiralStairCaseBuilder has simple lines that can be used as guides to help model more detailed handrailing for your staircase if required. (Similar to StairCaseBuilder).
    2. The Handrail Construction Guides (lines) should be set up to approximate / help you visualise the actual handrails and balustrades (verticals) you require. (If you don't need them, then just turn the layer off).
      Up to 4 Handrail Guides (horizontal lines) can be added.
    3. Don't overdetail the handrailing / verticals if they are never viewed really close up eg use a 12 or 16 sided circle for round sections etc or use rectangular sections. To help model more detailed handrailing, I can thoroughly recommend use of the following plug-ins:
    Bezier Spline (Fredo)
    Pipe Along Path (TIG)
    Profile Builder (Dale Martens)
    Any probs / suggestions / improvements / feedback etc - giz a shout
    Enjoy
    Howard L'
    Keywords: Dynamic Component DC Spiral Staircase Stairs Steps
    SpiralStairCaseBuilder_V4_UserGuide_Zipd.pdf
    DC_SpiralStairCaseBuilder_V4.skp
      dylan
      Looks like a really good idea Howard. Spiral staircases are always popular and can be tricky to model.
      Can't use it myself, not a Pro user but I'm sure it will be well received.
      http://dmdarchitecture.co.uk/
      • H Offline
        Howard leslie
        Dylan,
        You can use it !!!
        View - Toolbars - Dynamic Components
        Then use the Yellow Icon - Component Options
        ALL SketchUp users can USE Dynamic Components.
        Only PRO users can CREATE them.
        Hope this helps
        Howard L'
          dylan
          Thanks for the info Howard, I had completely forgot about that due to never experimenting with DC's.
          I had a play around with this and it works perfectly. Very useful, thank you.
          • E Offline
            Edson
            howard,
            would your DC be able to build something like the stair attached here?red_heli_stair.png
            http://www.mahfuz.arq.br
              charly2008
              Hi Howard,
              This component has certainly made a lot of work. But I find it a bit difficult to control because of the many parameters. I prefer the tool "Grow" for spiral stairs. So I can devote myself to the design of a single step and the handrail.
              I transform this into a component and then only needs to calculate the number of steps in the height and the number of turns.
              Charly
              • H Offline
                Howard leslie
                Edson,
                See attached.
                A very brief Tutorial put together quickly.
                Its to show the principle more than anything else.
                Hope this helps
                Bye
                Howard L'
                DC_SpiralStairCaseBuilder_V4 Solid_Balustrade_Example.zip
                • E Offline
                  Edson
                  hi howard,
                  thanks for taking the trouble to produce a tutorial. it certainly helps.
                  regards.
                  edson
                  • E Offline
                    Edson
                    thanks, howard! πŸ˜„
                    • H Offline
                      Howard leslie
                      Edson,
                      See attached *.skp
                      A more complete (better) example of a spiral staircase with solid balustrades.
                      (As opposed to the example shown in the tutorial above that was created very quickly)
                      Spiral Staircase with Solid Balustrade
                      See first example (above) for the method.
                      This is made exactly the same way.
                      1. Adjust Staircase variables, click Apply
                      2. Create Balustrades
                      3. Thicken up Balustrades, increase step width to hide slight gaps if reqd
                      4. Add solid risers if reqd
                      5. Adjust steps if reqd
                        Quite quick to create (approx 10 mins)
                        Enjoy
                        Howard L'
                      DC_SpiralStairCaseBuilder_V4_Solid-Balustrade-Example2.zip
                      • pyrolunaP Offline
                        pyroluna
                        πŸ‘ Like +1
