    How Is This Even Possible?---WTF?
    9 Posts 5 Posters 1.0k Views 5 Watching
    • Tim DanaherT
      Tim Danaher
      OK, so a student sent me this file: she was having problems push-pulling the hole on the front face through the face and getting a clean result—the hole would not appear on the back face. I tried everything to get a result: I managed in the end, but it was a real arseache.
      Can anyone else see what the problem is here? Is this a known bug? Or am I just not seeing something?
      Edit; BTW, is anyone else having problems orbiting & panning this file? I keep constantly getting lockups & the spinning beachball.
      Inges_Problem_Orig.skp
      Cheers,
      Tim
      http://vizarch.blogspot.com
      • thomthomT
        hmm... Not sure... but there's some hidden geometry around here:
        Removing these didn't help though.
        I did come across an bug:
          Normal! 😄
          Vertical are inclined!
          So you can't make a normal push pull 😉
          Faces are not parallal 😒
          • Tim DanaherT
            Tim Danaher
            Hah! thanks everyone!
            Cheers,
            Tim
            • thomthomT
              Think I might have it now:
              The model is extremely small - SU display all sorts of problems when you go less than 1mm-ish.
              • thomthomT
                Ah - heh! ignorem y last post then... 😒
                • TIGT
                  So, to recap...
                  The model is very small and needs re-scaling to a more appropriate size using the Tapemeasure tool.
                  There are bits of hidden geometry that need tidying up.
                  There are faces that are not parallel, so a PushPull won't punch a hole - but it could punch a cylinder through which you then intersect with the non-parallel face and tidy with the eraser...
                  • juan974J
                    juan974
                    Remember to scale before intersect
                    (sorry for bad english 😳 )
                    juan974 (Réunion island)
                    website : http://sketchucation.com/click.php?url=http://www.tarn.us
                    • juan974J
                      juan974
                      hello,
                      the probleme is that the start face and the end face aren t parallele see picture.
                      first solution : align bottom edge whit top edge :
                      second solution : make a component, copy and scale x10, push pull through the end face, select the end face and the cylinder, intersect whit selected, clean up and erase the big one (component) :
                      hope it helps
