    [Plugin] Draw Boundingbox
    50 Posts 20 Posters 38.0k Views 20 Watching
      Overview
      By request: http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=29375
      Draws a box from the selected Group/Component. Skewed instances supported.
      # CHANGELOG
      # 1.1.0 - 04.07.2010
      # * Support for 2D instances.
      # * Option between Faces or Construction geometry.
      # * Processes all groups / components in selection.
      # * Changed menu text.
      # * Fixed namespace name.
      Access
      Draw -> Boundingbox
      Supports ThomThom's Menu
      πŸ”» Download Extension
        dedmin
        OOOOhh! The plugin is ready even before think about it!! Big thanks!!
          dedmin
          Now we can position component's axis where we want on the bounding box and align the Fredo's scale and stretch with the bounding box!!! And easier dimensioning!!
          • simon le bonS Offline
            simon le bon
            Top Thomthom ! πŸ˜†
            and very useful
            http://i274.photobucket.com/albums/jj245/Spendauballet/ToolsThumbs/ruby.gif
            thank you once more
            ++simon
              So, are the faces not what you will be using? But instead just construction points for the boundingbox edges?
              Could easily make it draw the boundingbox with constructions lines and constructions points.
                dedmin
                Both! But option like this is welcome!! β˜€ β˜€
                  Update to 1.1.0
                  # CHANGELOG
                  • Didier BurD Offline
                    Didier Bur
                    Hi Thomthom,
                    I was wondering if it is really useful to store options in the registry (read/write_defaults).
                    Adding more and more reg keys will slow down the computer or not ? What do you think ?
                    DB
                      I don't think the overhead of extra registry items is that significant. I'd rather use the registry and the built-in API than to start littering small preference files about and adding extra complexity. Processing many small files also has its overhead.
                        Are there alternatives?
                          dedmin
                          πŸ‘ πŸ‘ πŸ‘ πŸ‘
                          • bagateloB Offline
                            bagatelo
                            Why the boundingbox is not attached with object? Why we cannot make boundingbox with only edges?
                              No one asked... πŸ˜‰
                                dedmin
                                Oh yes, please! πŸŽ‰ πŸŽ‰
                                • kenK Offline
                                  ken
                                  Thomthom
                                  Designing and fabricating large but still truck-able steel equipment, I find your plugin an easy to use method to determine the width, height and length of each section for the trucking company. You have made it easier to determine how to arrange a load on the truck bed to minimize the requirements for oversize load permits.
                                  Ken
                                    huh - again the simplest of plugins turns out to be of wider usage than I thought. I figured it was a rather obscure request. πŸ˜„
                                    alexpacio2013A 1 Reply Last reply πŸ™ Reply Quote 0
                                      agamemnus
                                      Very useful for my game -- to center models or stretch them appropriately utilizing the length/width/height ratios. Thank you.
                                        That can be used for packaging too πŸ˜‰
                                        Next step will be optimisation of placement of some objects for minimize the Bounding box πŸ˜‰
                                        • kenK Offline
                                          ken
                                          Now, that would be very useful.
                                          Ken
                                            Ben Ritter
                                            Thanks for sharing β˜€
                                            • 1 / 3
