    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 135.3k Views 16 Watching
    • simon le bonS
      simon le bon
      Hi Guys,
      I wanted to suggest you an exercise some month ago and had forgotten it under the pile..
      A challenge from Taff Goch Various rendering choices? -- Challenge!
      Rico91 proposition
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/geodesic001_th.jpg
      had given me some element of solution and so I reload my proposition:
      this was: " HOW TO DRAW A PARISIAN FENCE ? "
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee001.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee002.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee003.jpg
      In my mind the problem was "how to draw a sinusoid following the path of one element (component) and matching the good crossover at the various meeting points?"
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee003_b.jpg
      The solution you (Taff Goch) had applied to your geodesic weave sphere opens to me some idea to achieve this..
      -one element of answer is that each component goes with a neighbor mirrored one.
      clic to enlarge
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TaffGoch001_th.jpg
      But it remains a difficult exercise I guess 😒
      💚 simon
      PS: I'm completely found of your warehouse geodesic collection
        Seems this 2 components sufficient? 😉
        As it's 3D volumes, you can flip vertically the second components for have all possibilities! (front / back)
        click image
        Don't know how are the bottom and finished sides?
        • simon le bonS
          simon le bon
          Hi Pilou 😉
          Decompose into these two basic components seems a good idea.
          This way we can work with some simplicity on the problems of overlapping sinusoids. We can may be at the end use yours to make the component I was primarily thinking of in order to avoid any pb of seams
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee009_th.jpg
          close up
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee009_b_th.jpg
          Remain to draw these curved and angled sinusoids..
          @+ s
          • TaffGochT
            TaffGoch
            Simon,
            Consider how the manufacturer produced the fence. Q: With what did they start?
            A: A length of "wire," with a constant, repeated sine wave. This should be maintained in a 3D model. Keep all of the sinusoidal segments the same length.
            Truly, the sine segments along the top of the fence will be curved, but they should be maintained at the same length. I can demonstrate this evening, when I have some modeling time.
            -Taff
            "Information is not knowledge." -- Albert Einstein
            • ely862meE
              ely862me
              @taffgoch said:
              Simon,
              -Taff
              So true..i just quit because of that 😄 .
              Elisei (sketchupper)
              Come and See EliseiDesign
              • ely862meE
                ely862me
                When i thought i have figured it out 😒 😐 ,disaster(see how the wires intersect in the left down corner and ..of course ,they are not woven)
                More trials to go 😄 .
                  When you have flat model
                  Curved can be made by the Fredo Scale, no? 😉
                  • ely862meE
                    ely862me
                    hmm..just..wow..clearly u know some maths .
                    • simon le bonS
                      simon le bon
                      Wahoo! "bravo" Taff 👍 _ and I feel the result beautiful 😄
                      Now I know it can be done, I want to find the way: with your indications but without open your skp yet.
                      and I'm actually in front of the picture expecting something stand up from my perplexity 😒
                      I shall come back
                      *simon
                      • TaffGochT
                        TaffGoch
                        @simon le bon said:
                        ...and I'm actually in front of the picture expecting something stand up from my perplexity
                        Simon,
                        As I wrote earlier, I had a couple of false starts, until I studied the picture more closely...
                        Wave counting...
                        Each unit/increment is half of a sine wave (crest-to-trough, or trough-to-crest.) I finally recognized that each diamond was 6-units wide, having 5-unit side lengths. Only then would model components fit together properly.
                        -Taff
                        • broomstickB
                          broomstick
                          I know it's not the subject of this thread, but that image would make a great map with an opacity mask on it 😉
                          • GaieusG
                            True, I was also thinking about it. You can easily make it tilable horizontally, too - the only problem is that vertically it should be a bit higher so that you could apply it on more various (although of course, still limited) height.
                            • simon le bonS
                              simon le bon
                              Dear Taff,
                              I go slow, step by step. It is so cool to get you as professor 👍
                              1)how to make a sine-wave.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence001_th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence002_th.jpg
                              2)anatomy of the braided fence
                              Re I see 6 but not 5 1/2 sine-waves:?: ❓
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_th.jpg
                              OK we'll see later!
                              3)some testing just to see!
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_b_th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence004_th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence006_th.jpg
                              ..to be continued
                              😉 simon
                              • simon le bonS
                                simon le bon
                                @ely862me said:
                                Mr Simon,watch it, because they are now weaving.
                                😳 Ely, I don't understand what that means..
                                Well: there is a problem with my previous test.
                                If I use 6 by 6 half waves as shown, the wiring doesn't braid!!!
                                let me see...
                                *s
                                • ely862meE
                                  ely862me
                                  Edited:Mr Simon,watch it, because they are NOT weaving(braiding). (sorry 😳 not so usual words for me 😄 )
                                  • ely862meE
                                    ely862me
                                    I meant it s not braiding.
                                    U must follow the indication from Taff : 5 by 6(diagonal)
                                    • simon le bonS
                                      simon le bon
                                      Taff, you are right!
                                      And Ely too (you are quicker than me 😆 )
                                      The diamond need to be done with an odd number of semi waves.
                                      If I take the same wave and use 5 semi waves:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence007_th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence008_th.jpg
                                      that works perfectly.
                                      if I analyze better the fence -( I take a pen an a shit of paper 😉 and draw the wave blindely, just looking to the picture, i discover you are right: 5x5 semi waves!)
                                      A good point
                                      going to next step..
                                      simon
                                        shit of paper
                                        Otherwise an excellent study to compliment Taff's Geodesic Challenge.
                                        Look forward to the 'Loop' mathematics 😉
                                        Rich
                                        • ely862meE
                                          ely862me
                                          The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last 😆 ,but good luck anyway!
                                          • ely862meE
                                            ely862me
                                            shit of paper
                                            • 6
                                            • 1 / 6
