    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 130.0k Views 16 Watching
    • TaffGochT Offline
      TaffGoch
      Simon,
      Consider how the manufacturer produced the fence. Q: With what did they start?
      A: A length of "wire," with a constant, repeated sine wave. This should be maintained in a 3D model. Keep all of the sinusoidal segments the same length.
      Truly, the sine segments along the top of the fence will be curved, but they should be maintained at the same length. I can demonstrate this evening, when I have some modeling time.
      -Taff
      "Information is not knowledge." -- Albert Einstein
      • ely862meE Offline
        ely862me
        @taffgoch said:
        Simon,
        -Taff
        So true..i just quit because of that ๐Ÿ˜„ .
        Elisei (sketchupper)
        Come and See EliseiDesign
        • ely862meE Offline
          ely862me
          When i thought i have figured it out ๐Ÿ˜’ ๐Ÿ˜ ,disaster(see how the wires intersect in the left down corner and ..of course ,they are not woven)
          More trials to go ๐Ÿ˜„ .
            Remain to draw these curved and angled sinusoids..
            When you have flat model
            Curved can be made by the Fredo Scale, no? ๐Ÿ˜‰
            • ely862meE Offline
              ely862me
              hmm..just..wow..clearly u know some maths .
              • simon le bonS Offline
                simon le bon
                Wahoo! "bravo" Taff ๐Ÿ‘ _ and I feel the result beautiful ๐Ÿ˜„
                Now I know it can be done, I want to find the way: with your indications but without open your skp yet.
                and I'm actually in front of the picture expecting something stand up from my perplexity ๐Ÿ˜’
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee003.jpg
                I shall come back
                *simon
                • TaffGochT Offline
                  TaffGoch
                  @simon le bon said:
                  ...and I'm actually in front of the picture expecting something stand up from my perplexity
                  Simon,
                  As I wrote earlier, I had a couple of false starts, until I studied the picture more closely...
                  Wave counting...
                  Each unit/increment is half of a sine wave (crest-to-trough, or trough-to-crest.) I finally recognized that each diamond was 6-units wide, having 5-unit side lengths. Only then would model components fit together properly.
                  -Taff
                  • broomstickB Offline
                    broomstick
                    I know it's not the subject of this thread, but that image would make a great map with an opacity mask on it ๐Ÿ˜‰
                      True, I was also thinking about it. You can easily make it tilable horizontally, too - the only problem is that vertically it should be a bit higher so that you could apply it on more various (although of course, still limited) height.
                        simon le bon
                        Dear Taff,
                        I go slow, step by step. It is so cool to get you as professor ๐Ÿ‘
                        1)how to make a sine-wave.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence001_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence002_th.jpg
                        2)anatomy of the braided fence
                        Re I see 6 but not 5 1/2 sine-waves:?: โ“
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_th.jpg
                        OK we'll see later!
                        3)some testing just to see!
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_b_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence004_th.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence006_th.jpg
                        ..to be continued
                        ๐Ÿ˜‰ simon
                          simon le bon
                          @ely862me said:
                          Mr Simon,watch it, because they are now weaving.
                          ๐Ÿ˜ณ Ely, I don't understand what that means..
                          Well: there is a problem with my previous test.
                          If I use 6 by 6 half waves as shown, the wiring doesn't braid!!!
                          let me see...
                          *s
                          • ely862meE Offline
                            ely862me
                            Edited:Mr Simon,watch it, because they are NOT weaving(braiding). (sorry ๐Ÿ˜ณ not so usual words for me ๐Ÿ˜„ )
                            • ely862meE Offline
                              ely862me
                              I meant it s not braiding.
                              U must follow the indication from Taff : 5 by 6(diagonal)
                                simon le bon
                                Taff, you are right!
                                And Ely too (you are quicker than me ๐Ÿ˜† )
                                The diamond need to be done with an odd number of semi waves.
                                If I take the same wave and use 5 semi waves:
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence007_th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence008_th.jpg
                                that works perfectly.
                                if I analyze better the fence -( I take a pen an a shit of paper ๐Ÿ˜‰ and draw the wave blindely, just looking to the picture, i discover you are right: 5x5 semi waves!)
                                A good point
                                going to next step..
                                simon
                                  shit of paper
                                  ๐Ÿ˜ฒ
                                  Otherwise an excellent study to compliment Taff's Geodesic Challenge.
                                  Look forward to the 'Loop' mathematics ๐Ÿ˜‰
                                  Rich
                                  • ely862meE Offline
                                    ely862me
                                    The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ๐Ÿ˜† ,but good luck anyway!
                                    • ely862meE Offline
                                      ely862me
                                      shit of paper
                                      ๐Ÿ˜ฒ
                                      ๐Ÿ˜† ๐Ÿ˜†
                                        simon le bon
                                        OOPs!!! ๐Ÿ˜ณ
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/oh_shit.jpg
                                        OF
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/sudoku-papier-en-action.jpg
                                        sheet!!! ๐Ÿ˜Ž
                                        ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜†
                                        The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ,but good luck anyway!
                                        I can smell it is the point! Afraid to engage the step ๐Ÿ˜•
                                        s
                                        • TaffGochT Offline
                                          TaffGoch
                                          Recall that I, also, had a couple of "false starts." You have just re-solved my first false start. ๐Ÿ‘
                                          My second mistake involved the horizontal "rail" strips that run at the top and bottom of the fence. That spacing also has to be precise, or they won't braid, either.
                                          (And you can't cheat, by using a different sinusoidal spacing. The fence is supposed to be made of all the same sine-wave wire.) โ˜€
                                          -Taff
                                          • TaffGochT Offline
                                            TaffGoch
                                            When you have flat model, curved can be made by the Fredo Scale, no? ๐Ÿ˜‰
                                            That should work fine, for "bending" the top hoops, and the short segments just below the top rails.
                                            (Pilou, when I first read your post, I wasn't quite sure what you were talking about. Looking back, your idea makes sense, even though I haven't tried it.) ๐Ÿ‘
                                            -Taff
                                            • 1 / 6
