    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 126.1k Views 16 Watching
    • broomstickB Offline
      broomstick
      @simon le bon said:
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee003.jpg
      I know it's not the subject of this thread, but that image would make a great map with an opacity mask on it ๐Ÿ˜‰
        True, I was also thinking about it. You can easily make it tilable horizontally, too - the only problem is that vertically it should be a bit higher so that you could apply it on more various (although of course, still limited) height.
        • simon le bonS Offline
          simon le bon
          Dear Taff,
          I go slow, step by step. It is so cool to get you as professor ๐Ÿ‘
          1)how to make a sine-wave.
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence001_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence002_th.jpg
          2)anatomy of the braided fence
          Re I see 6 but not 5 1/2 sine-waves:?: โ“
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_th.jpg
          OK we'll see later!
          3)some testing just to see!
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_b_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence004_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence006_th.jpg
          ..to be continued
          ๐Ÿ˜‰ simon
            simon le bon
            @ely862me said:
            Mr Simon,watch it, because they are now weaving.
            ๐Ÿ˜ณ Ely, I don't understand what that means..
            Well: there is a problem with my previous test.
            If I use 6 by 6 half waves as shown, the wiring doesn't braid!!!
            let me see...
            *s
            • ely862meE Offline
              ely862me
              Edited:Mr Simon,watch it, because they are NOT weaving(braiding). (sorry ๐Ÿ˜ณ not so usual words for me ๐Ÿ˜„ )
              Elisei (sketchupper)
              Come and See EliseiDesign
              • ely862meE Offline
                ely862me
                I meant it s not braiding.
                U must follow the indication from Taff : 5 by 6(diagonal)
                  simon le bon
                  Taff, you are right!
                  And Ely too (you are quicker than me ๐Ÿ˜† )
                  The diamond need to be done with an odd number of semi waves.
                  If I take the same wave and use 5 semi waves:
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence007_th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence008_th.jpg
                  that works perfectly.
                  if I analyze better the fence -( I take a pen an a shit of paper ๐Ÿ˜‰ and draw the wave blindely, just looking to the picture, i discover you are right: 5x5 semi waves!)
                  A good point
                  going to next step..
                  simon
                    shit of paper
                    ๐Ÿ˜ฒ
                    Otherwise an excellent study to compliment Taff's Geodesic Challenge.
                    Look forward to the 'Loop' mathematics ๐Ÿ˜‰
                    Rich
                    • ely862meE Offline
                      ely862me
                      The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ๐Ÿ˜† ,but good luck anyway!
                      • ely862meE Offline
                        ely862me
                        shit of paper
                        ๐Ÿ˜ฒ
                        ๐Ÿ˜† ๐Ÿ˜†
                          simon le bon
                          OOPs!!! ๐Ÿ˜ณ
                          http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/oh_shit.jpg
                          OF
                          http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/sudoku-papier-en-action.jpg
                          sheet!!! ๐Ÿ˜Ž
                          ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜†
                          The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ,but good luck anyway!
                          I can smell it is the point! Afraid to engage the step ๐Ÿ˜•
                          s
                          • TaffGochT Offline
                            TaffGoch
                            Recall that I, also, had a couple of "false starts." You have just re-solved my first false start. ๐Ÿ‘
                            My second mistake involved the horizontal "rail" strips that run at the top and bottom of the fence. That spacing also has to be precise, or they won't braid, either.
                            (And you can't cheat, by using a different sinusoidal spacing. The fence is supposed to be made of all the same sine-wave wire.) โ˜€
                            -Taff
                            "Information is not knowledge." -- Albert Einstein
                            • TaffGochT Offline
                              TaffGoch
                              When you have flat model, curved can be made by the Fredo Scale, no? ๐Ÿ˜‰
                              That should work fine, for "bending" the top hoops, and the short segments just below the top rails.
                              (Pilou, when I first read your post, I wasn't quite sure what you were talking about. Looking back, your idea makes sense, even though I haven't tried it.) ๐Ÿ‘
                              -Taff
                                And now the coup de grace ๐Ÿ˜‰
                                http://clotureslestrie.com/store/images/vinyl_chain_link_roll.jpg
                                • TaffGochT Offline
                                  TaffGoch
                                  The fence, so far, looks too "wimpy" for my tastes.
                                  By increasing the amplitude of the sinusoidal paths, and increasing the diameter of the tubular cross-section circle, the fence is no longer made of heavy-gauge wire, but of sturdy wrought iron:
                                  Wrought iron fencing
                                  Achieved by editing only the component definitions. No new spacing or sine-wave construction required -- only sine-amplitude scaling, and new "follow me" extrusions, using a larger circle.
                                  (There are similar wrought-iron fences in New Orleans.)
                                  Model available in 3D Warehouse:
                                  Parisian Fence - "Beefier" Version
                                  Original model:
                                  Parisian Fence โ€ข Exercise
                                  -Taff
                                    simon le bon
                                    ๐Ÿคฃ
                                    Sorry Taff to be so slow ๐Ÿ˜•
                                    (I still haven't opened you skp)
                                    I have very carefully made a new sinusoid in order to match the 5 semi-waves of the diamond with the picture.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence009_th.jpg
                                    I agree with you that the same sine-wave have to be used for the horizontal "rail" strips,
                                    my mind is the good positioning of them give a starting point for all the geometry.
                                    I found (evidently) the same results as you
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence010_th.jpg
                                    Strangely, nothing actually leads me to your intuition of the shared spacing of 6 1/2waves !
                                    I have next tried to see if:
                                    The size of angles are significant in structure of the diamond ?
                                    The answer is Yes and No ๐Ÿ˜†
                                    The angle of the diamonds on the referential picture, taken by the upper side is about 37ยฐ
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence011_th.jpg
                                    If I diminish it to 20ยฐ the braiding is still efficient, depending only of the thickness of the string.
                                    but the point is that then the above horizontal "rail" strip doesn't match anymore at all!!
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence012_th.jpg
                                    This try leads me to understand that the ideal and true angle for the diamond is 60ยฐ Then the above horizontal "rail" strip match perfectly ๐Ÿ˜Ž
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence013_th.jpg
                                    Now I am going to see with the curve.
                                    My Idea is to bend the sinusoid as Pilou's way. I am going to try Chris Fullmer's Shape Bender to establish the curves..
                                    to be continued..
                                    ๐Ÿ˜‰ simon
                                    • TaffGochT Offline
                                      TaffGoch
                                      Careful, there, Simon... ๐Ÿ˜•
                                      ...that was my second mistaken false start! Before I discovered the semi-sinusoidal count, of 6 [NOT 6ยฝ for the horizontal spacing.]
                                      -Taff
                                      • TaffGochT Offline
                                        TaffGoch
                                        Simon,
                                        You are not the only one to learn by making/correcting mistakes. (The best kind of learning.)
                                        I just discovered a spacing mistake I made in the top-rail/hoop area! ๐Ÿ˜ฎ
                                        If you're sharp-eyed, you should be able to see the difference between the model I posted here (as an earlier attachment,) and the model I've posted (fixed) at the 3D Warehouse: Parisian Fence โ€ข Exercise
                                        http://sketchup.google.com/3dwarehouse/download?mid=1de34a55bdd876622137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1278298043000
                                        -Taff
                                          About le "coup de grace", I believe that it will be very easy with Shape Bender by Chris Fullmer ๐Ÿ˜‰
                                          • ely862meE Offline
                                            ely862me
                                            flat coup de grace
                                            • 1 / 6
