    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 173.3k Views 41 Watching
      arjunmax09
      @daniel s said:
      Works for me...
      Like Jeff said.. try using the 3rd icon... not the first one:
      [attachment=1:1596wm15]<!-- ia1 -->skin.jpg<!-- ia1 -->[/attachment:1596wm15]
      Daniel S
      Daniel...i used the same button for making the ramp...i select all the edges but nothing happens..Please upload screenshots or a video of how you actually make the ramp...I'm using SU 8 Pro..??
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        Daniel S
        Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
        I´m using SU8 Pro too.
        Do you have the latests versions of Curviloft and LibFredo6?
        For checking the latest version of curviloft go to "Tools>Fredo6 Collection>Curviloft>About..." should say Curviloft v1.0c.
        For checking the latest version of LibFredo6 go to "Window>LibFredo6 Settings>About..." should say LibFredo6 v3.5c.
        If you don´t have that versions you can download them from here: http://forums.sketchucation.com/viewtopic.php?f=323&t=28586
        If you have the correct ones, try to make the ramp with the ruby console open (go to Window>Ruby Console). Perhaps the ruby console shows an error that you can copy and paste here.
        Daniel S
          arjunmax09
          I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
          RAmp another try.rar
            Daniel S
            Here you have to use another plugin called weld.rb (you can download it at http://www.smustard.com/script/Weld)
            I attach a video showing how to make it work and .skp files.
            Daniel S
            ramp new welded.skp
            ramp new final.skp
            ramp new video.wmv
              arjunmax09
              Thanks Daniel...I'm finally able to make the ramp 😄 .. But for selecting the linear edges along one axis for welding is there a faster way rather than selecting them one by one??
                Daniel S
                You can try with Fredo6´s Hoverselect plugin (http://forums.sketchucation.com/viewtopic.php?f=323&t=18916). But it´s not working for me. Perhaps is a SketchUp 8 issue.
                Daniel S
                • K Offline
                  kathecasta
                  i'm following these same instructions, and it works at creating the ramp for me, so long as i don't click "reverse curve orientation" but i need it to be reversed!
                  When I try to skin it using the "reverse orientation" it doesn't create the top plane for the ramp, just the sides for some reason....
                  anyone have any idea why this is happening?
                  thanks!!
                  [attachment=0:36vg9dz6]<!-- ia0 -->skinning a ramp.gif<!-- ia0 -->[/attachment:36vg9dz6]
                  Daniel S
                  • G Offline
                    ghassan
                    wow
                    • ToboboT Offline
                      Tobobo
                      I cant believe i havent found this till now. This would have saved hours of time.
                      Thank you
                      Toby
                      Philippians 4:13
                        deprezzar
                        tanks Fredo!!!brilliant!!!
                          ddtaylor
                          thanks for sharing
                          • keea1111K Offline
                            keea1111
                            Can someone help me install this plug in? I am on Mac and I put the whole FredoTools folder in my plugins folder, but it is not active or even visible in SU? Much thanks, Keea
                            KEEA
                              mwm5053
                              Great plugin but I'm doing something wrong here I'm sure. Coming up with the same results as grim earlier in this thread. Thanks for the help
                              ramps.skp
                              2011 iMac
                              SU 2015 Pro, 2017 Make
                              V2 Twilight
                              macOS Sierra 10.12.5
                                thanesuan
                                thx a lot 😍
                                  Bertil
                                  cant get it to work on Mac
                                  • cottyC Offline
                                    cotty
                                    We will need some more information to help you ...
                                    my SketchUp gallery
                                    • W Offline
                                      wishiyyl
                                      Looks awesome Fredo! Congrats yet again,
                                      • U Offline
                                        urjuan
                                        Hi Everyone,
                                        Could someone help me..is this plugin only works for curves? how bout straight ramps with curve edges only?
                                        Thanks.
                                        • fredo6F Offline
                                          fredo6
                                          Thanks.
                                          Curvishear only requires that the contour is given as Sketchup 'curves' (as shown in the Entity Info panel).
                                          Please post a picture or the skp file for what you have in mind.
                                          Fredo
                                            mohsen
                                            How can I create this model? What is the plug?
                                            • 3 / 4
