    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 177.9k Views 41 Watching
      ddtaylor
      thanks for sharing
      • keea1111K
        keea1111
        Can someone help me install this plug in? I am on Mac and I put the whole FredoTools folder in my plugins folder, but it is not active or even visible in SU? Much thanks, Keea
        KEEA
          mwm5053
          Great plugin but I'm doing something wrong here I'm sure. Coming up with the same results as grim earlier in this thread. Thanks for the help
          ramps.skp
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • T
            thanesuan
            thx a lot 😍
            • B
              Bertil
              cant get it to work on Mac
              • cottyC
                cotty
                We will need some more information to help you ...
                my SketchUp gallery
                • W
                  wishiyyl
                  Looks awesome Fredo! Congrats yet again,
                  • U
                    urjuan
                    Hi Everyone,
                    Could someone help me..is this plugin only works for curves? how bout straight ramps with curve edges only?
                    Thanks.
                    • fredo6F
                      Thanks.
                      Curvishear only requires that the contour is given as Sketchup 'curves' (as shown in the Entity Info panel).
                      Please post a picture or the skp file for what you have in mind.
                        mohsen
                        How can I create this model? What is the plug?
                        • jeff hammondJ
                          do you have sketchUp pro? if so, looks like a job for Solid Tools
                          make the full sheet using curviloft then slice it up with solid tools
                          EDIT--
                          mohsenwall.skp
                          click pic --> larger view
                            Or after the "Make Solid" use the Slicer by TIG 😉
                            • E
                              Elric00
                              There's a SU2015 version?
                              • fredo6F
                                Yes, take the latest version of FredoTools and also update LibFredo6 by precaution.
                                All my plugins work from SU6 to SU15.
                                  shoaibnot
                                  how download curvishear1.5a
                                    AMOR1919
                                    All of you creators of plugins are bunch of genius. Thank you for all
                                      Archimaker
                                      CurviShear indirmek istiyorum ama olmuyor. Yardımcı olabilir misiniz?
                                      • 3 / 4
