    Pregnancy avoidance
    37 Posts 10 Posters 97.8k Views 10 Watching
    • R
      rv1974
      There's some strange feature (personally I'd call it a bug)- moving the arc\curve endpoint in Z direction distorts the plan view (alters the radius value).
      Is some some tool or ruby that would make the curves keep original plan view.
      On the picture:
      1 The Original geometry- red AB arc
      2 Movin B to B1 causes blue\green pregnancy (depends on arc\curve)
      3 The Yellow one is what really I need.
      Thank you in advance
      • R
        remus
        i think the easiest thing to do would be to use Fred06's tools on surface plugin to draw the yellow line on then clean up the remaining geometry.
        • R
          rv1974
          Yes I know. But it's too complicated to build additional surfaces and then clean it.
          All I want is to move vertex in distortion free mode .
          • Fredos plugin is not always work smooth to me:
            http://screencast.com/t/M2Q1NTMzZWUt
          • R
            remus
            Well i think your best option is to do it manually, it'll probably be easier than you think...
            • Chris FullmerC
              Try exploding the arc (right click on it and choose explode arc) before moving its vertices. That might help,
              Chris
              All my Plugins I've written
              • R
                rv1974
                @chris fullmer said:
                Try exploding the arc (right click on it an dchoose explode arc) before moving its vertices. That might help,
                Chris
                The blue one is the explode+weld inheritor.
                • Chris FullmerC
                  Yeah, SketchUp is just not going to do it how you want. Its not a bug, its just the way SU works.
                  • Wo3DanW
                    Wo3Dan
                    rv1974,
                    Like Chris I don't see this as a bug. The arc remains an arc, all its segments coplanar. What you are after is probably the helix by moving a single vertex.
                    That will not happen. The helix does not have coplanar segments. You need to do this manually.
                    Wo3Dan
                    Edit: the yellow curve is either the 3D helix mentioned above or a coplanar curve created by intersection with a simple face. No arc involved.
                    • M
                      mac1
                      rv1974
                      You are trying to 'morph" an arc into a 1/4 section of elipse. A intersection of cylinder and plane with the plane perpendicular to the axis of cylinder is a circle, non perpendicular will be a ellipse and arc will not fit that very well. If you draw a triangle using the cylinder center(base) and the two desired end points gives you a plane ref which a section plane can be algned to and intersected with the cylinder to get what you want. You will have to first use the section tool option to make the slice a group to get the intersection.
                      • R
                        rv1974
                        Just thinking aloud.. The original SU product placement is urban design\architecture. Historically
                        the plan (plan view) is the 'alpha and omega' of the design process. I really can't see any benefit\use in curve bulbing. It appears there's a good niche for some ruby geek- the 'Interpolated_vertex_move.rb'.. or something like that 😉
                        • N
                          notareal
                          I would use ...zorro!
                          • R
                            rv1974
                            for Seppuku? 😄
                            • N
                              notareal
                              @rv1974 said:
                              for Seppuku? 😄
                              I don't think that so drastic method is in need 😉
                              Zorro 2 http://forums.sketchucation.com/viewtopic.php?f=323&t=16038
                              Tip for use http://forums.sketchucation.com/viewtopic.php?p=216509#p216509
                              • R
                                rv1974
                                Take the arc's end and drag it upward. Take a look at the twisted result in the top view. Zorro.rb is a totally diffrent story- the cylinder in the example picture is just a visual aid.
                                • X
                                  xrok1
                                  you would have to rotate it to keep the original radius, what your doing by moving one end is changing the radius. 👊
                                  you could also draw your arc from A to B1 and set whatever radius you need or snap the radius to existing geometry. 😉
                                  “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                  • R
                                    rv1974
                                    Take a look at this skp file. Hope it'd explain the problematics better then my broken english does.
                                    ramp.skp
                                    • jeff hammondJ
                                      jeff hammond
                                      like wo3dan said, that's probably helix that you're after.. when you move the vertex of the curve, it stays proportionally correct...
                                      [edit] oh, just saw your latest example.. a little different i guess.
                                      helix.skp
                                      dotdotdot
                                      • jeff hammondJ
                                        jeff hammond
                                        i haven't tried it but you might want to check out slope edges in the 1001bit suite
                                        http://www.1001bit.com/products/slopeedges.shtml
                                        dotdotdot
                                        • N
                                          notareal
                                          This explains the need much better... nothing that zorro can do. 😞 But if the issue where like you originally posted, then it's a different story.
                                          • R
                                            rv1974
                                            Hi mates! As I can see the disscussion went in the wrong direction (mea culpa).
                                            I have no problem to build this damn ramp and the things like that (with at least 2 difftent ways:
                                            1.extrude plan outline->surface tools->loft (more correct)
                                            2.followmeandkeep.rb->interset with extruded plan (less correct))
                                            Both ways take time and efforts. The aim of this thread was to catch some ruby maker's eye to
                                            the neat (IMHO) idea- to move curve's vertexes in a kinda 'interpolation mode' and without plan distortion, or maybe to find
                                            the already existing script.
                                            Sorry for the lack of clarity ☀
                                            • 1 / 2
