    ANY IDEA of can i create this?
    15 Posts 8 Posters 1.9k Views 8 Watching
    • M
      maximas
      hiii all users and masters of stechup
      any idea of can i create this?
      http://www.popavenue.com/pub/Architecture/.Airspace-Tokyo-02_m.jpg
      thanks for your reply and help
      • TIGT
        Short answer - with a lot of hard work. πŸ˜‰
        Long answer -Capture.PNG a sampler - you'll need to spend more than the five minutes I did doing this tutorial - perhaps you could draw over an image of the forms to get the feel for the 'morphology' πŸ€“
        • M
          maximas
          thanks for the super fast awesome reply!!
          but how can i erease Hole on faces , when i use the ereaser they are only line that will be erease 😞 any plugin for select and directly erease forms??
          • massimoM
            massimo Moderator
            Yes you can use this plugin: + canc πŸ˜‰
            • TIGT
              If you select [click-on] just face[s] and press the delete key the face[s] will erase leaving any edges behind.
              There are several tools - e.g. thomthom's "selection-toys" to manipulate selections, so if you have selected all of the faces AND edges at the 'holes' level by using a fence [after PuhPulling] you will want to remove the edges from the selection... then the holes' faces remain selected - press delete and they are gone... πŸ€“
              • massimoM
                massimo Moderator
                ...or if you have many holes you could try this. πŸ˜„
                • TIGT
                  Good tip - I had forgotten about that one - you'd use it before doing the PushPulling........
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    To erase may holes quickly try this:
                    1 - Select all.
                    2 - Press and hold the SHIFT key to Add/Subtract from the selection.
                    3 - While stil pressing the SHIFT key, double click anywhere on the area between the holes. This will deselect it as well as all the perimeters of the holes and the perimeter of the rectangular area that you want keep.
                    4 - Delete the selection. Only the inside face of all the holes will be deleted.
                    Just ideas.
                    • GaieusG
                      @jean lemire said:
                      Hi folks.
                      1 - Select all.
                      Just ideas.
                      πŸ‘
                        Classic πŸ˜‰
                        • bazB
                          baz
                          @jean lemire said:
                          Hi folks.
                          1 - Select all.
                          Just ideas.
                          Thanks Jean, I was just about to search for the plugin which does this, you've reminded me again that plugins dont really do anything which is not doable anyway in native su.
                          baz
                          here is that plugin:
                          http://forums.sketchucation.com/viewtopic.php?p=243598#p243598
                          • TIGT
                            Excellent tip Jean - sometimes you think a plugin is needed when it's as quick to do it manually... β˜€
                              to do it manually
                              yes...but it's finally the prog who works πŸ˜‰
                              • bazB
                                baz
                                not to take anything away from the fab ruby gurus who have given us so much more in su.
                                i think it would be well to remind the newbies that as pilou said, its the 'program' which does the work.
                                rb's certainly help the workflow, but you still have to know what you want to achieve.
                                remember 'garbage in, garbage out'?
                                some of the setups that i see on utube defy belief, every plugin ever invented in the toolbar, leaving a business card to design on.
                                there was a fella here a while ago, 'gully' that helped me with a boat hull. he stitched it for me from the stations or 'splines'. twas beyond me, but thru his generosity, i began to understand how the program works.
                                this arvo i was having a play with the 'loft by spline' beta by fredo, and it works perfectly for me, some others, alas, were having trouble.
                                I think it works for me perhaps because i have some small understanding of how it works.
                                i have always admired the boulder teams' philosophy... start simple, keep it simple, eg:you have to 'find' the sandbox.
                                in some ways, i think it would be better if access to plugins was restricted to pros.
                                on the other hand, give em enough rope etc πŸ˜„
                                bazgully's hull
                                gullyhull.skp
                                • pyrolunaP
                                  pyroluna
                                  ...or you could just texture the face with a semi-transparent png...
