    Ruby/Google SketchUp/Modelroom
    9 Posts 6 Posters 1.7k Views 6 Watching
      soue
      Help please,
      *sorry my englisch is not very gut !
      I am facing the problem to create an automatic assignment of wall pairs.
      Requirement is the implementation of multidimensional search trees (with
      a window looking in Ruby for Sketchup), that are needed for the
      (statistically) the automatic assignment of vertices or faces.
      Using this tool, I would then build a wall surface (observation)
      topology or allocate land in different rooms walls (wall map of relative
      dimension pairs). With the help of two plug-ins for Sketchup space
      extraction should succeed me - if I only knew HOW ?????
      Whom I could ask there? Which specialists are there? Could I please get
      a hint as to whether and where such an issue is discussed?
      Towards the despair,
      Souebayar
      • Chris FullmerC Offline
        I don't quite understand. Do you have an image that explains what you need?
        All my Plugins I've written
          soue
          yes i have two images (see attachment).Thanks
          Testkorp.skp
          RAUMKONSTRUKTION.skp
            Jim
            I don't understand the request. Any ideas?
              Can I put it the way I think you mean...
              How do you use Ruby to find wall areas ?
              âť“
                soue
                hello TIG,
                Thanks for your interest in helping out.
                Thats what I meant TIG
                  Wall area, is that the only purpose, or is it part of a larger script?
                  If you right click any material in your material browser you can choose to get the total area of the faces which has that material applied.
                  • honoluludesktopH Offline
                    honoluludesktop
                    Ask question in your language. "Google translate" may be able to turn it into english.
                      soue
                      The problem lies in:
                      SketchUp-Ruby + knowledge
                      -Find the correct algorithm
                      Key points:
                      Digital Model-Building
                      Rooms extract
                      Coordinates of wall edges in the same coordinate space of the rooms
                      transform
                      -Nearest Neighbour Search, depending on the amount of data, two-step procedure,
                      First nearest neighbor and only then take into account nor the normal
                      Wall view from above:
                      A wall is defined as two pairs of opposing surface area (front side and back side) include a hollow space.
                      Thank you
