Ruby/Google SketchUp/Modelroom
Help please,
*sorry my englisch is not very gut !
I am facing the problem to create an automatic assignment of wall pairs.
Requirement is the implementation of multidimensional search trees (with
a window looking in Ruby for Sketchup), that are needed for the
(statistically) the automatic assignment of vertices or faces.
Using this tool, I would then build a wall surface (observation)
topology or allocate land in different rooms walls (wall map of relative
dimension pairs). With the help of two plug-ins for Sketchup space
extraction should succeed me - if I only knew HOW ?????
Whom I could ask there? Which specialists are there? Could I please get
a hint as to whether and where such an issue is discussed?
Towards the despair,
Souebayar -
I don't quite understand. Do you have an image that explains what you need?
I don't understand the request. Any ideas?
Can I put it the way I think you mean...
How do you use Ruby to find wall areas ?
hello TIG,
Thanks for your interest in helping out.
Thats what I meant TIG -
Wall area, is that the only purpose, or is it part of a larger script?
If you right click any material in your material browser you can choose to get the total area of the faces which has that material applied.
Ask question in your language. "Google translate" may be able to turn it into english.
The problem lies in:
SketchUp-Ruby + knowledge
-Find the correct algorithmKey points:
Digital Model-Building
Rooms extract
Coordinates of wall edges in the same coordinate space of the rooms
transform
-Nearest Neighbour Search, depending on the amount of data, two-step procedure,
First nearest neighbor and only then take into account nor the normalWall view from above:
A wall is defined as two pairs of opposing surface area (front side and back side) include a hollow space.
Thank you
