    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 299 Posters 2.8m Views 297 Watching
    • fredo6F Offline
      fredo6
      @architure said:
      Just ask me for the file if needed!
      Yes the file would be useful, as this seems to be a special case.
      Fredo
        Architure
        Hi there,
        Sorry for my late reply. Here is the attached 2018 skp file . You can see that the selected mode is only applied between the first 3 curves.
        Let me know if I can provide more information.
        Cheers
        seat back.skp
        • fredo6F Offline
          fredo6
          NEW RELEASE: Curviloft v1.8a - 31 Oct 18
          Curviloft 1.8a is a maintenance release for bug fixing.
          See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
          Main post of this thread
          Fredo
          • Z Offline
            zswseu
            Looking forward to another excellent work.
              rv1974
              In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards(thanks Thom there're Edge tools so it's not manual). Could there be an optionto keep them straight when creating?
              • fredo6F Offline
                fredo6
                Not too sure what you mean by 'straighten'.
                Maybe an example would be helpful.
                Fredo
                  rv1974
                  Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' πŸ˜„
                  • fredo6F Offline
                    fredo6
                    I really need to refresh the plugin with more explicit control of the different options (and maybe selecting a few ones which make sense). Currently, Curviloft rather exposes the options that come from the algorithm, up to the user to find out what is appropriate. That's why I still leave it in Beta after all these years!
                    Fredo
                    • jgbJ Offline
                      jgb
                      I wholeheartedly agree, but please also update your last 32 bit version as well.
                      I cannot run 64 bit apps on my old PC. I'm still running Make V.13.
                      jgb
                        Loft along the path: can we modify the path after launch the plugin?
                        I don't see it! (the path)
                        • fredo6F Offline
                          fredo6
                          What do you mean?
                          Do you have issues with Curviloft on Sketchup 2013?
                            rv1974
                            I searched hard to find how to save this method as default but no luck. Is it possible at least make this tool to remember last used settings at least? If it could remember them permanently it'd be even better. Thank you.
                            • fredo6F Offline
                              fredo6
                              Do you use the latest version (1.8a)? It keeps the latest settings across Sketchup sessions and I checked it works with SU2013.
                                rv1974
                                Great news! β˜€ Gone refreshing ALL of yours
                                  rv1974
                                  I checked, v1.8.a doesn't keep my last used settings (at least junktion by connected lines method)
                                  • fredo6F Offline
                                    fredo6
                                    I forgot to say that you need to enable the option in Default Parameters....
                                    Fredo
                                    • jgbJ Offline
                                      jgb
                                      What do you mean?
                                      It's not that I have issues with CL in SU-2013, just I thought the latest CL update versions were 64 bit only. I will D/L the latest later this week.
                                      jgb
                                      • fredo6F Offline
                                        fredo6
                                        In principle, Ruby script are independent from the OS details (hopefully), but sometimes dependent on the SketchUp version.
                                        The trend is effectively that I will progressively transition my scripts toward SU2016 and above, but I'll keep usually the existing version, at least in maintenance mode, and the new version would probably include more functionality. This is what happens with RoundCorner and FredoCorner. So when you see FredoLoft published for SU2016+, you would still have access to Curviloft, even if it would likely be in maintenance mode.
                                        • jgbJ Offline
                                          jgb
                                          Thanks again. πŸ˜„ I'll now upgrade SU to 2016 (32bit) and all my plugins/extensions as well.
                                          jgb
                                          • E Offline
                                            Einstein
                                            I made a loft and added a forced pair for each vertex of profile. Now there are some unnecessary pairs (yellow ones) between vertices and I was thinking if it's possible to remove them before applying the loft.
                                            In this case both profiles - upper and lower - are hexagons. So intuitively, pairs should be created between vertices only. Instead, Curviloft connected each vertex of lower profile to edge midpoint of upper profile, which created a lot of unnecessary edges. So I'm thinking if I could force the tool to always match vertex-to-vertex when profiles have the same number of verts.
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 65
                                            • 66
                                            • 60 / 66
