    Twist in a surface...i dont get it right.
    5 Posts 3 Posters 582 Views 3 Watching
    • K
      Keksschredder
      Hi Guys, i have a question to curved surfaces?! I use the follow me tool to construct a surface winding between two lines. But now i habe three lines and sketchup ignores the third one. Its quiet difficult to tell. Have a look by yourself,... and thanks for reading.
      First picture is a look from behind above, second from above direct. You see the emty bow? The surface should follow all three lines...like a sail over a frame.
      Keksschredder
      cooky-shredder
      surface-1.skp
        Can you upload the file to see more clearly? It's hard to make out what you're trying to achieve
        • K
          Keksschredder
          ok i attached it. thx.
          • TIGT
            Try my ExtrudeEdgesByRail tool - it's in the Extrusion Tools Zipped set...
            You select the profile, and then the two rails - in this case there's not 'melding-profile' so you select the profile again..Capture.PNG
            • K
              Keksschredder
              Thats what i was looking for. Thank you very much Tig.
