    1001bit Extrude Problems...
    47 Posts 10 Posters 7.5k Views 10 Watching
    • Tim DanaherT Offline
      Tim Danaher
      I've posted on the 1001bit forum but got no replies, so maybe someone here can help?
      Breuer Chair Tryout.skp
      I go through the procedure of choosing the profile, then selecting the end of the path and...nothing happens, apart from an empty group appearing in the Outliner.
      Anyone got any ideas?
      TIA,
      Cheers,
      Tim
      http://vizarch.blogspot.com
        Open the Ruby Console and see if any error messages appear. If so - report them to the author.
          Tim Danaher
          Done.
          Cheers,
          Tim
              Tim Danaher
              Thanks, TIG... I can do it with FollowMe and FMAK... the specific question was why 1001bit can't do it.
              Cheers,
              Tim
                FollowMe and FMAK both require the face squarely on the end of the path - 1001-extrude and EEbyFace do not - also EEbyFace works on several unconnected or branching paths - unlike FollowMe etc...
                I don't know 1001-extrude - I think it can work with a 'flat' face and place it to suit - have you tried welding the edges into a curve as the path ?
                Incidentally my PipeAlongPath or TubeAlongPath scripts would also give you a similar result...
                • X Offline
                  xrok1
                  i found the 1001bit tools guy doesn't give much support. 😒
                  β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                    Seems 1001 tools is not appropriated for the Breuer path!
                    There are "torsions" inside!
                    It's specifed on the icone tooltip 'without torsion' πŸ˜‰
                      Tim Danaher
                      This is becoming a 'mare...
                      All I want is a robust, no-hassle extrude-along-path solution for my students... FMAK works, but doesn't smooth the resulting extrusion and 1001bit...
                      TIG, will try your suggestions... how do I weld the path? Is that a plug-in?
                      Frenchy... when you say 'torsions'... Have I drawn the various curves in different directions? (Tooltips? I don't got no stinkin' tooltips...)
                      xrok... indeed... 😠
                      Cheers,
                      Tim
                        My Extrusion Tool set is perhaps too complex for this - find my 'PipeAlongPath.rb' [crai etc] and use that - you don't need a 'welded' path for that tool - just continuous edges/arcs selected - it will make a smooth welded path for you.
                        I can't believe you survive without 'weld.rb' - get it free from 'Smustard' - select any joined up lines/arcs etc and it makes a polyline curve from them - useful for many of my Extrusion tools that need you to select curves, and also generally making polylines etc for extruding smoothly...
                        πŸ˜„
                          @ TIM : This is more clear? πŸ˜„
                          Sorry it's in French, but your tooltip is in English β˜€
                          I suppose "no torsion" is meaning without direction changment between different plans πŸ˜‰
                          PS I can't believe that you don't know the Plug Weld πŸ˜„
                          Use SU without Plugs is today a sort of task! πŸ’š
                            And another thing : calculate of the object result can take some time : so be patient!
                            You can make your Breuer chair with this 1001 function but you must make it in several part!
                            So I believe that is not the good function for that!
                              Tim Danaher
                              OK, cheers, TIG...
                              Frenchy... mais j'ai pas de tooltips (sous MacOS X)... pas du tout!
                              Cheers,
                              Tim
                              • X Offline
                                xrok1
                                i tried it by welding the path first, doesn't work!
                                i think tig's extrude edges by face will be hard to beat. (even though his extrude tools are all named weird πŸ˜† ) should be extrude face along edge... but we can live with it cause they're so damn great! 😍
                                i usually spend more time trying to figure out the code of what each name means than using the tool 😳
                                  yes πŸ˜„
                                    @ Tim
                                    You see that the calculate is beginning when you can't move the blue cross with the mouse after the click on the beginning curve!
                                    That is not a "torsion" here πŸ˜‰
                                    PS Sorry I have not MAC and absolut know how it works πŸ’š
                                    But you must have the Help line!
                                      • X Offline
                                        xrok1
                                        don't pretend you didn't know 🀣
                                          πŸ˜‰
                                          The tools
                                          "Extrude"
                                          "Edges"
                                          "by"
                                          "something"
                                          Edges
                                          Face
                                          Faces
                                          Lathe
                                          Loft
                                          Rails
                                          RailsByFace
                                          RailsToLattice
                                          Vector
                                          As they are a 'set' I have kept the naming quite consistent...
                                          An 'Edge' is a 'Line' in SUp-speak
                                          I know that often these tools need 'Curves', but then these are made from 'Edges'...
                                          The first combines edges with edges
                                          The next extrudes a face along edges
                                          The next uses faces as the basis of the extrusion
                                          The next 'lathes' the edges' curve
                                          The next 'lofts' the edge-sets' curves
                                          The next uses 2/3/4 edge curves as profiles/rails
                                          The next extrudes a face along ditto
                                          The next makes a lattice using ditto
                                          The next extrudes the edges along a vector
                                          How better to describe them ???
                                          πŸ˜’
                                            They make perfect sense to me!
                                            For example, i wish I had a plugin which would allow me to extrude an edge rather than a face along a curved rail. Now that'd be cool!
                                            A sort of Extrude Edge by Rail tool! Hey I could even chose to extrude faces too? Or maybe a lathe like action around an axis?
                                            Damn that'd cool 😎
                                            • 1 / 3
