    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Crazy problem with Right Click
    53 Posts 14 Posters 12.3k Views 14 Watching
    • fredo6F Offline
      fredo6
      @jhauswirth said:
      The problem is Ruby scripts are calling-
      UI::Command.new
      and not attaching the new command to a menu item.
      If you want to verify this run-
      for i in 0..1000 do
      cmd = UI::Command.new("Tester") { UI.messagebox("Hello World") }
      I can see Ruby scripts creating new commands on each right mouse click.
      Every new command creates a unique command ID in SU and there are only 1000
      command IDs available. Normally a command is attached to a menu and when
      the menu goes away the IDs are recycled, but since these commands are not
      attached to a menu, they don't get recycled.
      I'm going to try and figure out how to dump the list of commands (they have
      menu item text) so that people can see who's causing the problem.
      Just to understand what exactly went wrong, can you clarified whether the issue is:
      case 1) creating more than 1000 object UI::Command, regardless of any other consideration
      case 2) or creating Command objects and not attaching them to menus
      In my scripts, the faulty code which I modified was in the style:
      UI.add_context_menu_handler do |menu|
         if some tests...
             cmd = UI;;Command.new(menutitle) { do_action}
             cmd.status_bar_text = tooltip
             menu.add_item(cmd)
      So the issue seems to be the Creation of Command (case 1), not the attachment to menu (case 2). Possibly, since this happens in the contextual menu of the Selection tool, it may be that SU does not release the menu items.
      Thanks to advise
      Fredo
        AlexMozg
        I wrote a plugin completely fix this problem.
        If you use my plugin is no need to adjust the already installed plugins that use the context menu.
        Soon I'll post it for testing.
        πŸ˜„
          πŸ˜„
          The earliest view of your fix would be greatly appreciated ! πŸŽ‰
          • Dan RathbunD Offline
            Dan Rathbun
            @thomthom said:
            Named "_0.rb" to make it load first. (or does underscore make it load last...?)
            Yes '_' (underscore) loads AFTER '!' (exclamation) and alpha characters 'A'..'Z'
            FYI: because both Windows and OSX are both case aware, but case preserving systems; the lower case 'a'..'z' are collated (in directory lists,) in the same positions as the uppercase letters, even though the lower case come after the underscore in the character set.
            We must be careful when using special characters to control script load order, as the "allowable" filename characters may vary from system to system. It would be nice to have a list of characters that can be used on both OSX and WIN, and those to avoid (like those characters that are used in URIs ['#','?','&'.'='].
            So far.. I am only comfortable using exclamation and underscore.
            I'm not here much anymore.
              I believe that the ASCII characters disallowed in file-names are \/:*?"<>|
              I have used a # to prefix my early loading rubies for some time, without any reported problems on both PC or Mac.
              but then some apps don't even like a <space> in their file-names. πŸ˜•
              We know that 'accented' characters also cause problems in Ruby/Sketchup... πŸ˜’
                Dan Rathbun
                This is list that is displayed in the standard Windows warning dialog when you try to use one of these characters when renaming a file.
                Can anyone find a link for UNIX/Linux/BSD (and therefor OSX,) invalid filename characters ??
                But I would have to vote for putting '#' on the list of DON'Ts because it is used to specify an anchor (html <A> target,) in a URI.
                The same goes for '%' as it's used for character numeric codes in URIs.
                Yes.. I would vote for always using an underscore in place of a space, within a script filename.
                Yup... this is due to the differences in character sets, even though there are some accented characters in the UTF8 set, it's a pain getting Windows to recognize them (using the 1.8.x branch of Ruby.)
                [**P.S.:**This may change in the future... if we can twist Google's arms into checking the Ruby version before they set the encoding (ie: KCODE) and calling the appropriate Ruby call per version. In the 1.8.x branch the call is rb_set_kcode; but in ver 1.9.x KCODE has been deprecated, and rb_set_kcode has been removed, in favor of one of the calls in encoding.c (perhaps rb_enc_set_index, see the encoding.h file.) Until this is done, Sketchup will not load Ruby ver 1.9.x, because we just get an error that the entry point for rb_set_kcode cannot be found (because it's not in the 1.9.x branch.)
                Not only is 1.9.x faster, but it has much better support for character encoding.]
                NOTE: Sorry this has gone off-topic, perhaps one of the moders can break these filename posts off into a new topic.
                  Here is a list of Unix file-name character exceptions
                  http://en.wikipedia.org/wiki/Filename#Reserved_characters_and_words
                  Seems that ' %' is disliked, but otherwise it's pretty much as the Windows restricted set, isn't it ?
                  Also see http://support.grouplogic.com/?p=1607 too...
                  Interestingly that says a Mac can accept any character in a file-name except a ' :' [the folder separator], or starting with a ' .' - reserved for special files [hidden?]; the length limit is 256 for OS-10 [or 31 for OS-9].
                  Windows:- a file-name can't end with a <space> or a '.', be named as one of the 'protected names' - e.g. com1 [no extension], be longer than 255/256/260 characters depending on FAT/NTFS/extension, or additionally contain a ' ^' on 'FAT' systems only.
                    Doesn't . at the beginning on UNIX system mean hidden files/folders?
                      @lapx said:
                      Has anyone found a fix to this problem of the right click menu. I cant access any many of the commands 😠
                      Yes - update your Fredo plugins.
                        lapx
                        Thanks Tom! Ill do. Wow there's so many...fredo scale n tools on surface.
                          lapx
                          Has anyone found a fix to this problem of the right click menu. I cant access many of the commands 😠
                            lapx
                            Updating all plugins did not solve the grey out issue. I know there are suggestions of renaming and unloading plugins but this is a pain obviously. Is there a way to see or track visually the limit if there is such a thing? Is it really the number of programs that are casuing the problem? How many are too many? And which one's are the memory hogs?
                            ps. i'm getting duplicate information in my menus. What is the cause of this?
                            attached is a copy of my plugins folder (this may be dated by a few months).
                            Thanks!
                            Plugins.txt
                            • H Offline
                              hitechbob Newcomers
                              I have figured out what was causing the problem. When using Windows 11 and Chrome browser, the right-click rendered a truncated (worthless) menu. It seems MS has cleverly disabled right-clicking on any other browser EXCEPT for MS Edge. Imagine my surprise.
                              • 3 / 3
