    Question: How to model a random perforated surface...
    10 Posts 7 Posters 5.6k Views 7 Watching
    • E Offline
      entersketchup
      Hello everyone, first of all I would like to say that this is my first post in my favorite Sketchup resource website, and I'm grateful for this community โ˜€.
      I'm struggling with modeling a large perforated surface (a wall) with random sized circular and/or elliptical holes. I thought of using the Protrude Plugin's division feature then using Subdivide on each extrusion, then intersecting the result with my wall, but it was a bad idea because Sketchup crashed when I tried it. The result I wish to have is close to this:
      http://www.decodir.com/wp-content/uploads/2009/11/Lightmos-Thonglor-by-Architectkidd-550x851.jpg
      I kind of wish there was a plugin that could generate 2D voronoi-like random patterns on surfaces. If there was a way to convert the square divisions produced by Protrude.rb into circles and ellipses then that would be amazing. Are there any suggestions from the Sketchup gurus?
      Thanks ๐Ÿ˜„
      • numbthumbN Offline
        numbthumb
        Something like this?
        http://www.smustard.com/script/BoolTools
        http://forums.sketchucation.com/viewtopic.php?f=79&t=23046&p=195391&hilit=holes+surface#p195391
        Comfortably numb...
        • E Offline
          entersketchup
          Thanks numbthumb, but I was thinking more of how to produce random sized holes. Using the protude.rb plugin I managed to do random sized openings but I'm limited to squares/rectangles.
          I wish to replace these random squares/rectangles with circles/ellipses. I know I can do them manually but I'm planning to do a lot so it wouldn't be practical... So I'm asking if there is a faster way to do it.
          (This is just a test, I'm planning to create more and smaller openings)
            My thought would be to use this excellent plugin in conjunction with numbthumb's suggestion
            Still a lot of manual clicking but faster than doing it completely with SU's native tools
            • soloS Offline
              solo
              I was thinking of using the component spray tool by making the component cut an opening, thus being able to spray a bunch of circular flat components at random sizes onto a surface.
              I tried to create an example but for some reason I cannot get the component spray tool not to overlap each other, if I can solve this then it shound work for what you need.
              http://www.solos-art.com
              • Chris FullmerC Offline
                All great suggestions so far. I would also suggest maybe placing all your circles and using a plugin like my Scale and Rotate randomly script. Place all the circles somehow, then run my script on them to get them to all adjust their sizes. Might still require a lot of work to move them all around so they don't overlap I suppose.
                Plus one of the most interesting features of those circles is their placement. They look to have been placed with a fractal algorithm. So far no plugin in SketchUp that I know of does that yet. It wouold not be hard to do, if you know fractal geometry mathematics - which I do not.
                Chris
                All my Plugins I've written
                • E Offline
                  entersketchup
                  Thank you all for your suggestions, I think those tools (booltools, spray, scale/rotate) would be perfect for the job. Yes Chris I agree that the point of interest is the placement, but I don't know geometry math and that's why I thought of using Protrude's (greeble) divison to create some kind of a mathematics-based placement at least...
                  I see the community active and interested in a fractal and a voronoi plugin for SU, so hopefully we'll see a good one in the near future. But until then, for the meantime I think clicking and adjusting manually with the mentioned tools will be totally fine ๐Ÿ‘ .
                  Thanks ๐Ÿ˜„
                    I think there is a voronoi plugin, but it seems like people have more problems than success with it.
                    • Y Offline
                      yahia mito
                      looks soooo beautiful ๐Ÿ˜ฎ
                      could u plz attach this plugin ( if it works on SU ) ๐Ÿ‘
                        Hi Yahia,
                        Here is the topic of the plugin (attached to the bottom of the first post in a ZIP file):
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=8116
                        To tell the truth, I do not know what it is doing so you will need to discover yourself.
