    How to disable sounds
    8 Posts 5 Posters 4.2k Views 5 Watching
    • brookefoxB
      brookefox
      This is new for me: context menu choosing and picks now elicit sounds (ping, ding, ching). I can't find the setting to disable it. doesn't seem to be an OS thing; I generally turn all sounds off in progs and Windows. Might it be tangled with a newly installed plugin?
      ~ Brooke
      • GaieusG
        Do you have some "housebuilder" plugin installed lately?
        • TIGT
          If so edit the file with Notepad and find/replace every instance of UI.beep or UI::beep with #UI.beep or #UI::beep so no more 'beeps'... πŸ˜•
          • brookefoxB
            brookefox
            Yes, yes !!!
            Will do.
            Thank you very much.
            ~ Brooke
            • soloS
              solo
              Can you post that file when done, so a lazy ass like me can just replace my file with your modified one?
              I also have those annoying sounds.
              http://www.solos-art.com
              • brookefoxB
                brookefox
                Of the three .rb's, HouseBuilder, HouseBuilder_extension and HouseBuilderTool, only the latter had either of the culprits (UI.beep).
                When I get verification of the results I'll post it for you, Solo, if you still lay claim to that status. Seems to me this is naughty and probably unintentional behavior by the routine, to make ripples extending beyond when it is explicily invoked(?).
                ~ Brooke
                  Hi guys,
                  Tim was also troubled by the beeps and rewrote the script here.
                  It's the very last post that has the .rb file. I haven't tried it but just remember when he posted!
                  • brookefoxB
                    brookefox
                    Thank you, Rich. I guess I'll go that route since tim says he 'fixed' some other issues.
                    Solo, I'll assume you as well are taken care of.
                    ~ Brooke
