    TEXT SIZE?
    3 Posts 2 Posters 277 Views 2 Watching
    • pmolsonP
      pmolson
      Is there a way to force text created with the Text/leader tool to not re-size when zooming in & out?
      Drives me crazy!
      pmo
      • TIGT
        You can give text a 'fixed height' instead of a 'points size'...
        The first way gives it a fixed height in inches/mm etc; the second adjusts the text dynamically as you zoom etc so it's always the same size 'on-screen'... which is what I think you are fed-up with...
        You set this in the Model Info Text / Change Font section or later using the similar tools in Entity Info...Capture.PNGBoth about the same.Capture2.PNGZoomed in... points text adjusts so it's the same size on screen - here the 2 images are the same size so only the relative heights become apparent...
        • pmolsonP
          pmolson
          Thank you Tig.
          p
