    Give thickness
    11 Posts 4 Posters 1.1k Views 4 Watching
    • M
      masheen
      Hi all, im a newbie here but I have been working with SU for a couple of years now and still love it! πŸ˜›
      I have a modeling query that im hoping someone can help me with - I have a rectangular box with rounded edges that i need to give a thickness to (see links here:
      http://i458.photobucket.com/albums/qq307/hyaground/Box2.jpg
      http://i458.photobucket.com/albums/qq307/hyaground/Box1.jpg
      I'm guessing the answer is a script or plug-in or some sort? please advise as i'm out of ideas on this one!
      Many thanks in advance πŸ˜„
      • TIGT
        Fredo's JointPushPull will probably do what you want... http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
        Be sure to get all of the files you need installed into the right folders - read the instructions carefully... There are many useful tips in that thread too... πŸ€“
        • M
          masheen
          Thanks for the quick response TIG! πŸ˜‰
          Looks a little complicated so i will try it out this evening when i have more time...
          • TIGT
            It's really easy - just make sure you have it set to keep the original faces... the 'inset' is less than the radii... and finally orient the faces... Capture.PNG
            • M
              masheen
              Ok thanks - for some reason i am not able to view the .png you have attached, i get this meassage:
              You do not have the required permissions to view the files attached to this post.
              maybe its because im a new member still - also i have to keep logging in every time i click on something which is very annoying! πŸ˜•
              • TIGT
                You will get full privileges shortly - the 'trial period' is to deter spammers who might only login once or twice and can therefore be trapped before going public...
                I'll PM you the image also...
                • GaieusG
                  Wait a inute, guys, "newly registered members" should be able to access attachments! What's up in the Plugins forum then???
                  • M
                    masheen
                    Worked fine in the end thankyou - i am using the 'Normal PP' for now as the others give me weird results. It mentions 'documentation' in that thread although i can t find it - any ideas? i could do with some kind of written guide as i dont feel im using the plugin properly... πŸ˜•
                    Also i have the idea that my drawing has become 'heavy' since creating all these new faces on one small model - is there a way to check the face count of a model/component so i can compare before and after for example?
                    Thanks again for all your help so far πŸ˜„
                    Chris
                    • TIGT
                      Did you get the latest version JointPushPull - 25 Aug 09.zip ?
                      That has a 'tutorial' PDF file in its subfolder...
                      Tutorial Joint Push Pull - English - v1.1 - 20 Feb 08.pdf
                      • M
                        masheen
                        I have the latest version thanks and after reading the documentation everything made a lot more sense - although i am still unable to tell what change i have made to the size of the component itself - i'm afraid of generating heavy models as i need to make quick changes to the model in front of the client and i cant afford a sluggish model during navigation...
                        • M
                          mac1
                          masheen
                          Read this it may help http://sites.google.com/site/sketchupsage/faster
