    Face Sun Plug-in
    19 Posts 7 Posters 4.5k Views 7 Watching
    • C
      construsol
      Hi.
      As a follow up of my previous topic about Archaeoastronomy and Sketchup, I'm wondering if there is a Plug-in for "Face Sun". It would work like the existing feature "Face Camera", but in this case the selected plane would face directly straight to the sun in such a manner that the sun rays fall perpendicular to that plane. Thanks in advance for any info.
        This one gives 45°shadows Elev45Shadows.rb by TIG
        I don't know if that can help you 😄
        • C
          construsol
          Thank You Pilou, but what I need is not about shadows, but about selecting a plane and rotate it in such a way that it faces the sun. Thanks for your reply.
          • J
            Jim
            A plug-in does not exist as far as I know, but it wouldn't be hard to write.
            How's your Ruby programming?
            • C
              construsol
              Jim:
              I also think it wouldn't be hard, but I dont do Ruby, or any kind of programming. I hopping someone can help making the program or telling where I can learn to do it.
              • TIGT
                We can get the vector to the Sun's rays ( Sketchup.active_model.shadow_info["SunDirection"]). This should be equivalent to the face.normal, so we just need to make a rotation transformation to align these two vectors [say about the face.bounds.center with the axis obtained from the cross of the vectors ?] and then apply that to the face's vertices en mass (I assume it'd be a loose 'face' ??)... 🤓
                • thomthomT
                  Would also need a Shadow observer to update when as the Sun changes.
                  • TIGT
                    That's assuming it was to auto-update its orientation - otherwise a one-off - 'set_the_face_to_look_at_the_sun_now' tool would simply reorient the face to look direct at the current sun's position - but if the sun moved the face wouldn't ?
                    • thomthomT
                      I got the impression live update was part of the request.
                      But if a one of adjustment is all that is needed then it'd simply things - avoiding pesky observers.
                      • TIGT
                        With it auto-updating via 'pesky observers' you would get a weird model, with things turning to the sun as it changed between scenes like a time-lapse movie of flowers ??? Better, but much more convoluted code-wise...
                        • facerF
                          facer
                          The SunTools plugin by Guedi Capeluto has a feature called "Sun View"
                          which gives an axonometric view from the Sun.
                          • C
                            construsol
                            Hi Thomthom:
                            Live update is not needed, just make a plane face to a direction in which the sun would be in a specific date and time, and keep that orientation fixed even if the sun starts to move.
                            • thomthomT
                              Made a quick plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=27499
                              • GaieusG
                                I have also seen a dynamic component of a solar panel that followed the sun.
                                • thomthomT
                                  Yea - good point. Though I never manage to find it when I want to use it as an example...
                                  • C
                                    construsol
                                    Thank you very much, this is just what I needed with the "Face Sun" Plug-in. I tested it by putting a perpendicular line to the plane that is facing the sun and it does not cast shadows, so it looks that it works great. One question, ¿How can a plane of a cube be selected and then the entire cube, not just the plane, faces the sun? Thanks again.
                                    • GaieusG
                                      I got it - posted here:
                                      Subject: Solar panels that track the sun
                                      @dsarchs said:
                                      The solar panel is under the "solar panel" tab for this component
                                      • thomthomT
                                        I could make it orient the connected geometry to the selected faces. Doubt I have time until after the weekend though.
                                        • C
                                          construsol
                                          Thom:
                                          I would greatly appreciate it if you can do this. Thanks again for your help.
