    Face Sun Plug-in
    19 Posts 7 Posters 4.5k Views 7 Watching
      I got the impression live update was part of the request.
      @construsol said:
      . It would work like the existing feature "Face Camera"
      But if a one of adjustment is all that is needed then it'd simply things - avoiding pesky observers.
        With it auto-updating via 'pesky observers' you would get a weird model, with things turning to the sun as it changed between scenes like a time-lapse movie of flowers ??? Better, but much more convoluted code-wise...
        • facerF Offline
          facer
          The SunTools plugin by Guedi Capeluto has a feature called "Sun View"
          which gives an axonometric view from the Sun.
            construsol
            Hi Thomthom:
            Live update is not needed, just make a plane face to a direction in which the sun would be in a specific date and time, and keep that orientation fixed even if the sun starts to move.
              Made a quick plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=27499
                I have also seen a dynamic component of a solar panel that followed the sun.
                  Yea - good point. Though I never manage to find it when I want to use it as an example...
                    construsol
                    Thank you very much, this is just what I needed with the "Face Sun" Plug-in. I tested it by putting a perpendicular line to the plane that is facing the sun and it does not cast shadows, so it looks that it works great. One question, ¿How can a plane of a cube be selected and then the entire cube, not just the plane, faces the sun? Thanks again.
                      I got it - posted here:
                      Subject: Solar panels that track the sun
                      @dsarchs said:
                      The solar panel is under the "solar panel" tab for this component
                        I could make it orient the connected geometry to the selected faces. Doubt I have time until after the weekend though.
                          construsol
                          Thom:
                          I would greatly appreciate it if you can do this. Thanks again for your help.
