    Shortcut to edit group - unable to create
    8 Posts 4 Posters 1.5k Views 4 Watching
    • brookefoxB Offline
      brookefox
      I understand that I need to select a group to be able to create a shortcut to edit same but I can't seem to do it even so. Search results here seem to say otherwise.
      ~ Brooke
        Jim
        Works for me.
        Select the Group
        Window > Preferences > Shortcuts
        Filter: Group
        Select: Edit/Item/Edit Group
        Click in Add Shortcut
        Press: Shift-E
        Press [ + ] button (I always forget this one.)
        Click OK
          brookefox
          Thanks much. The filter was the key. I wonder why the choice is not available without the filter, which I thought would be limiting rather than extending the selection set. Perhaps my glasses are still fogged.
          ~ Brooke
            There are many commands that are only available in 'certain circumstances'...
            For example to shortcut 'Reverse Face' - if nothing were selected then there's nothing for Preferences > Shortcuts... even with a Filter for 'Reverse'...
            But, if you first Select a Face, then do Preferences > Shortcuts > Filter 'Reverse' will give you the command [hooray] - set it to say Shift+Q...
            While you are at it why not set 'Orient' to Alt+Q ?
            So... if there are commands you'd like to shortcut to then first ensure that the 'context' is set properly before activating Preferences to attempt the Shortcutting...
            • X Offline
              xrok1
              you do realize you can just doubleclick a group to edit it?
              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                Well said !
                However, some commands are not so easily done and shortcuts do help..............
                  brookefox
                  Yes, thanks. Sometimes, though, as you know, SU seems to shift the pick in the course of double clicking (if there may be some ambiguity owing perhaps to entities being in stacked (e.g., groups in front of a face). And the shortcut will hopefully be faster when having to drill in to perform multiple group edits (my present concerns are dims acting as text, or maybe TIGs 2DText (? I forget).
                  ~ Brooke
                    brookefox
                    I did think I had the basic context thing in mind. I'm still not with the filter, but will try o keep it in mind.
                    And I will now go in search of prefab shortcut selections, as I know folks with good experience have put them together, acknowledging that one size won't fit all, and that whatever is implemented must be remembered to be a short cut.
                    ~ Brooke
