    Sandbox from Scratch question
    6 Posts 4 Posters 555 Views 4 Watching
      Starlex
      Hi!
      I'm trying to create terrain using sandbox tools
      I have to create terrain on poly-figurefigure
      When I use Scratch tool, I get terrain plane as a squarescratch square
      Is it possible to get smthg like this (I edit pic @ Photoshop)result
      Thanks for suggestions!
        The 'site' shape and the sandbox mesh surface are separated as the mesh is grouped.
        Selected the 'site' and Edit>Cut it.
        Double click the mesh-group to edit it, then Edit>PasteInPlace the site.
        The site now merges with the mesh.
        Erase the parts of the mesh you don't want.
        Now you have a mesh the shape of the site - manipulate its levels etc as desired..........
          Starlex
          Thanks!
          but I have to ask: How can I improve and speed up erasing parts of mesh, that I don't need?
          maybee, there is draping with erasing parts of mesh to fit object....
          • X Offline
            xrok1
            @starlex said:
            Thanks!
            how are you erasing now? eraser tool or select/delete?
            “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            • X Offline
              xrok1
              this is how i would do it. drag select then delete as much as possible, then use the eraser tool for the finer deleting along the edges.
                • You can also smooth the mesh surface first
                • then drape the terrain shape on it
                • triple click anywhere with the select tool
                • double click in the middle with the Shift key pressed (to deselect the middle part)
                • and hit the Delete button
                  You can unsoften you mesh later - or leave it like that (you would probably soften it eventually anyway) as the other sandbox tools work on smooth surfaces, too - or you can display hidden geometry any time from the View menu.
