    [Plugin] Latticeizer
    14 Posts 8 Posters 24.6k Views 8 Watching
    • TIGT Online
      Xrok thought that this deserved its own thread since he always finds it impossible to locate. 😉
      TIG's Latticeizer Latticeizer.rbPayPalButtonEDIT: TIG - file added...
      PS: TIG's LatticeMaker is more flexible http://forums.sketchucation.com/viewtopic.php?p=244981#p244981
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
          archdeacon
          hi there,
          great tool but i would really love to be able to generate lattices over curves as well (can;t upload image for some reason). Lattice maker splits the lattice. i want to make it solid. I am trying to make a gridshell. Any ideas?
          • TIGT Online
            Have you looked at LatticeMaker ?
            • KrisidiousK Offline
              Krisidious
              How do I miss these things? Great Plugin TIG...
              Latticemaker
              http://sketchucation.com/forums/viewtopic.php?f=323&t=28223
              By: Kristoff Rand
                archdeacon
                TIG i have already installed latticemaker. But i can appreciate that latticizer and lattice maker do different things. i want to use the latticizer type of lattice in curved surfaces. Is it feasible?
                • TIGT Online
                  Make the latticeizer lattice-group flat but elevated above your curved surface [group]
                  Use Sandbox's Drape or my SuperDrape and 'project' the lattice's line-work onto your curved surface.
                  If you color your latticezer parts and use SuperDrape then the materials are replicated on the curved surface.
                  This projection is flat.
                  You can use tools like JointPushPull to pull up the frames etc...
                  • demD Offline
                    dem
                    sometimes it happens after editing
                    (su8)
                    • TIGT Online
                      @dem
                      How big is this geometry ?
                      Can you post an example SKP - before and after - with settings you entered in the dialog...
                        An old true gem! 😎
                          jla303
                          TIG, first, I love Lattice-izer, thanks so much. Is there a way to set it up so when you apply the command the group stays within the original dimensions? The way is working now, if I have a group that is 4ft by 4ft, after the lattice is created it will measure 4'2" by 4'2" if the lattice width is set up to 2"
                          Thanks,
                          Luis
                          • TIGT Online
                            Knowing it'll have a 2" frame, you need to Scale it in X, typing in 3'10" [or 46"], then in Y with the same dimension.
                            You can Scale to an exact size provided that the input numbers have dimension suffixes...
                            Now it's 3'10" square - i.e. the final required sizes less one frame-width of 2".
                            When the 2" frame is finally added to perimeter the total size is 3'10"+2" = 4' square.
                            If you want to keep exact dimensions to the inner divisions, then set the perimeter's sizes before measuring out the dividing lines to the required dimensions.
                            • I Offline
                              inaoos777
                              Hi TIG,
                              Trust all is well. Thank you for some great plugins. Will it be possible to generate a .rbz of the Latticeizer? I am unable to install it in sketchup 2018.
                              • TIGT Online
                                It's available in the PluginStore https://sketchucation.com/pluginstore?pln=Latticeizer
                                Get its RBZ and install it, just like any other...
                                Alternatively use the SketchUcation ExtensionStore³ from within SketchUp itself, to Auto-Install it...
                                It works just fine in the newer SketchUps...
                                But note that it's not been signed for full compatibility with newer SketchUp, so your 'Extension Loading Policy' needs to be set to 'Unrestricted' for it to load and appear in the Extensions menu...
                                1 Reply Last reply Reply Quote -1
