    [Req] Check for N-Gons
    25 Posts 6 Posters 4.7k Views 6 Watching
    • K Offline
      Khai
      would it be possible to write a Ruby (or Tig, for you to add this to Manifold...!) that checks a mesh for N-Gons? (N-Gon face that is greater than 4 sides)
        remus
        Your wish is my command. Give me 5 mins...
        Version 3:
        works over the entire model (in groups and components), thanks to TIGs handy little snippet.
        Adds all N-gons to a new selection
        Tells you how many N-Gons there are in the model
        Added a Tri check which can be accessed by typing tri_check() in to the ruby console
        ngon_check.rb
          remus
          Here you go, copy and paste this in to jims/alexs web console and click run.
          model = Sketchup.active_model
          entities = model.entities
          selection = model.selection
          n = 0
          entities.each{|e|
            if e.is_a? Sketchup;;Face
              if e.edges.length > 4
                n += 1
          if n > 0
            UI.messagebox("Contains N-Gons (Faces with >4 sides)")
          else
            UI.messagebox("N-gon free!")
            remus
            ...or just install this script as usual.
            ngon_check.rb
            • K Offline
              Khai
              thanks πŸ˜„ I owe you one πŸ˜„
              • K Offline
                Khai
                oops.... it's not working... everythings coming up as N-Gon free....
                • jeff hammondJ Offline
                  jeff hammond
                  khai, i'm pretty sure it's not looking inside groups/components otherwise it appears to be working.
                  dotdotdot
                  • K Offline
                    Khai
                    aah explode it first... I tried with just groups and selecting the group... did'nt think to explode it first..
                      remus
                      Sorry i didnt reply, internet cut out.
                      As jeff pointed out its not gong through faces that are within groups/components for some reason. This version will go through all the faces in the current context, so a slight improvement but not much better. Not sure why it doesnt work on all the faces in the model straight off πŸ˜•
                      ngon_check.rb
                        Remus
                        Your current script finds all faces in the the active_entities - those in the current 'edit' session.
                        Perhaps do that if selection.length==0, but do it on selection if >0 ?
                        You could also do it on entities which would be all faces in the base model.
                        To get absolutely all faces in the model and its definitions [components and groups] use
                        faces=[]
                        model=Sketchup.active_model
                        model.entities.each{|e|faces<< e if e.class==Sketchup;;Face}
                        model definitions.each{|d|d.entities.each{|e|faces<< e if e.class==Sketchup;;Face}}
                        ### then test 'faces' array for 4-sidedness ones...
                        It depends which faces you want to list - i.e. all or all-active or all-selected ???
                        • soloS Offline
                          solo
                          Wondering out aloud.... so what then? you find the N-gons what do you do with them? divide them into triangles?
                          http://www.solos-art.com
                            My triangulateFaces or triangulateQuads already does that ?
                            I expect he wants to find un-triangulated faces > quads for some other esoteric processing .................
                            πŸ˜•
                            • K Offline
                              Khai
                              actually to divide them into Quads (preferred) or Tris - I use Sketchup as a modeler for other programs you see, they prefer no N-Gons... (Mainly poser content)
                                remus
                                TIG, i realise the current script only works in the current context (in a group etc.), it was on purpose as i thought it was more useful than only being able to check the faces in the highest context.
                                On another note, does entities not include faces, edges etc. that are within components? If so that would explain why khai was having trouble with it...
                                  active_entities is everything in the current edit session - i.e. in the model or a group or component being edited.
                                  entities is everything in the model - as in model.entities but stops short of nested stuff so it lists all geometry, groups, instances etc.
                                  You also use entities for other containers like groups or component_definitions - e.g. group.entities and definition.entities. again these stop short of listing nested stuff.
                                  To find ALL entities you need to do my trick of iterating through the model.definitions and going through the entities of each definition...
                                  Remember too that if you are changing entities always use an array as in ents.to_a - changing entities as you ' each' loop through them leads to unpredictable results as the entities list constantly changes and so it becomes confused...
                                    remus
                                    Cheers for the explanation πŸ‘
                                    • K Offline
                                      Khai
                                      presto reserectus!
                                      http://forums.sketchucation.com/viewtopic.php?f=169&t=24681&p=247955#p247955
                                      I'm wondering if this can be expanded now to highlight the Ngons? we're finding with Sculptis it rejects any faces with more than 4 faces....
                                        remus
                                        Try this in the webconsole. To be honest your probably better off using TIGs triangulate faces ruby, though...
                                        entities = model.active_entities
                                        n = 0
                                        entities.each{|e|
                                              n += 1
                                              selection.add(e)
                                        if n > 0
                                        else
                                        • K Offline
                                          Khai
                                          webconsole?
                                          and I explained back in this thread.. I can't tri the mesh. I'm moving from here (I love the modeler!) to app that don't like things being totally tri's... so that ruby's no good to me.
                                            remus
                                            Webconsole is a handy little ruby that lets you run bits of ruby in SU without having to package it as a separate file. You can find it here: http://sketchuptips.blogspot.com/2007/08/plugin-webconsolerb.html
                                            Just install it as usual, open SU, hit the appropriate menu item, copy and paste the code in and click run.
                                            I'll get going on a normal version, but no promises. Its been a while since ive written a ruby.
                                            • 1 / 2
