    [Req] Check for N-Gons
    25 Posts 6 Posters 4.2k Views 6 Watching
      Khai
      aah explode it first... I tried with just groups and selecting the group... did'nt think to explode it first..
        remus
        Sorry i didnt reply, internet cut out.
        As jeff pointed out its not gong through faces that are within groups/components for some reason. This version will go through all the faces in the current context, so a slight improvement but not much better. Not sure why it doesnt work on all the faces in the model straight off πŸ˜•
        ngon_check.rb
          Remus
          Your current script finds all faces in the the active_entities - those in the current 'edit' session.
          Perhaps do that if selection.length==0, but do it on selection if >0 ?
          You could also do it on entities which would be all faces in the base model.
          To get absolutely all faces in the model and its definitions [components and groups] use
          faces=[]
          model=Sketchup.active_model
          model.entities.each{|e|faces<< e if e.class==Sketchup;;Face}
          model definitions.each{|d|d.entities.each{|e|faces<< e if e.class==Sketchup;;Face}}
          ### then test 'faces' array for 4-sidedness ones...
          It depends which faces you want to list - i.e. all or all-active or all-selected ???
          • soloS Offline
            Wondering out aloud.... so what then? you find the N-gons what do you do with them? divide them into triangles?
              My triangulateFaces or triangulateQuads already does that ?
              I expect he wants to find un-triangulated faces > quads for some other esoteric processing .................
              πŸ˜•
                Khai
                actually to divide them into Quads (preferred) or Tris - I use Sketchup as a modeler for other programs you see, they prefer no N-Gons... (Mainly poser content)
                  remus
                  TIG, i realise the current script only works in the current context (in a group etc.), it was on purpose as i thought it was more useful than only being able to check the faces in the highest context.
                  On another note, does entities not include faces, edges etc. that are within components? If so that would explain why khai was having trouble with it...
                    active_entities is everything in the current edit session - i.e. in the model or a group or component being edited.
                    entities is everything in the model - as in model.entities but stops short of nested stuff so it lists all geometry, groups, instances etc.
                    You also use entities for other containers like groups or component_definitions - e.g. group.entities and definition.entities. again these stop short of listing nested stuff.
                    To find ALL entities you need to do my trick of iterating through the model.definitions and going through the entities of each definition...
                    Remember too that if you are changing entities always use an array as in ents.to_a - changing entities as you ' each' loop through them leads to unpredictable results as the entities list constantly changes and so it becomes confused...
                      remus
                      Cheers for the explanation πŸ‘
                        Khai
                        presto reserectus!
                        http://forums.sketchucation.com/viewtopic.php?f=169&t=24681&p=247955#p247955
                        I'm wondering if this can be expanded now to highlight the Ngons? we're finding with Sculptis it rejects any faces with more than 4 faces....
                          remus
                          Try this in the webconsole. To be honest your probably better off using TIGs triangulate faces ruby, though...
                          model = Sketchup.active_model
                          entities = model.active_entities
                          selection = model.selection
                          n = 0
                          entities.each{|e|
                            if e.is_a? Sketchup;;Face
                              if e.edges.length > 4
                                n += 1
                                selection.add(e)
                          if n > 0
                            UI.messagebox("Contains N-Gons (Faces with >4 sides)")
                          else
                            UI.messagebox("N-gon free!")
                            Khai
                            webconsole?
                            and I explained back in this thread.. I can't tri the mesh. I'm moving from here (I love the modeler!) to app that don't like things being totally tri's... so that ruby's no good to me.
                              remus
                              Webconsole is a handy little ruby that lets you run bits of ruby in SU without having to package it as a separate file. You can find it here: http://sketchuptips.blogspot.com/2007/08/plugin-webconsolerb.html
                              Just install it as usual, open SU, hit the appropriate menu item, copy and paste the code in and click run.
                              I'll get going on a normal version, but no promises. Its been a while since ive written a ruby.
                                remus
                                Ok, here you go.
                                Several improvements in v.3:
                                works over the entire model (in groups and components), thanks to TIGs handy little snippet.
                                Adds all N-gons to a new selection
                                Tells you how many N-Gons there are in the model
                                Added a Tri check which can be accessed by typing tri_check() in to the ruby console
                                ngon_check.rb
                                • StinkieS Offline
                                  Stinkie
                                    Khai
                                    not working right.... it's reporting everything has 18 N-gons... even a cube.....
                                    wish I could help 😞 but I'm no programmer 😞
                                      remus
                                      Hmmm, most unusual. Working ok for me. Could you post a problem model?
                                        Khai
                                        no point.. since even a simple six sided cube is reporting '18 Ngons' tho, if I add 3 Ngons... it reports '21 Ngons' !
                                        for some reason it's reporting 18 instead of 0....
                                        Edit
                                        Found the problem. it's checking all the entities in the scene. example : a new scene automatically has 18 Ngons = the default human figure.
                                        even deleting him, he registers in the Ngon check.. do a purge and remove him totally, it reports correctly...
