    [Req] Check for N-Gons
    25 Posts 6 Posters 3.9k Views 6 Watching
      remus
      Ok, here you go.
      Several improvements in v.3:
      works over the entire model (in groups and components), thanks to TIGs handy little snippet.
      Adds all N-gons to a new selection
      Tells you how many N-Gons there are in the model
      Added a Tri check which can be accessed by typing tri_check() in to the ruby console
      ngon_check.rb
      • StinkieS Offline
        Stinkie
        Thanks!
        • K Offline
          Khai
          not working right.... it's reporting everything has 18 N-gons... even a cube.....
          wish I could help 😞 but I'm no programmer 😞
            remus
            Hmmm, most unusual. Working ok for me. Could you post a problem model?
            • K Offline
              Khai
              no point.. since even a simple six sided cube is reporting '18 Ngons' tho, if I add 3 Ngons... it reports '21 Ngons' !
              for some reason it's reporting 18 instead of 0....
              Edit
              Found the problem. it's checking all the entities in the scene. example : a new scene automatically has 18 Ngons = the default human figure.
              even deleting him, he registers in the Ngon check.. do a purge and remove him totally, it reports correctly...
              • 2 / 2
