    Ungrouping a group
    6 Posts 4 Posters 17.9k Views 4 Watching
    • N
      NenadE46
      Hi everyone!
      I did stupid mistake now i want to fix it. ๐Ÿ˜ณ
      I grouped part of my model and then I've added in to a layer that OK, but then I changed my mind and from the same group I've create another layer, now... ๐Ÿ˜• first layer I can show/hide by checking/unchecking in the layer window, the second layer i can't show/hide until i check the first layer that's because this two layers are in the same group so.... i want to ungroup this part (or whateve it is) and create separate group for this two layers. I.... found something about this problem here โžก http://sketchup.google.com/support/bin/answer.py?hl=en&answer=95642 but I can't see that "Ungroup" menu item???
      So.... can someone help me โ“ pleeease ๐Ÿ˜ณ
      erm... Sorry for my English. (If there is some grammar mistakes ๐Ÿ˜• )
      • X
        xrok1
        right click on your group and choose explode. ๐Ÿ˜‰
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • N
          NenadE46
          ๐Ÿ˜ฎ Just... that... That's it!?!?! I did it !!! Thanks man! ๐Ÿ˜ Thaaanks! You hear that ๐Ÿ˜„
          It's simple but when you don't know where it is... ๐Ÿ˜†
          Well done ๐Ÿ‘
          • X
            xrok1
            my pleasure. i know how frustrating the little things can be. ๐Ÿ‘Š
            • A
              a different name
              Thanks for your answer, xrok1.
              Unnecessary confusing UI - should be directly in the edit menu under Group, right?.. ๐Ÿ˜•
              • TIGT
                It is in the main menu too ?
                The context-menu varies with the selection, and it is replicated in drop-down menu associated with the last item in the Edit menu.
                The title of the last item will vary depending on the selection - here, for a group it'd say 'Group' etc - like Entity Info does...
